LS2 oil pan fit an LS6??????????
Old 02-19-2005, 07:14 PM
Speedpup's Avatar
Default LS2 oil pan fit an LS6??????????
It may be better for road racing application. Some one on Corvette Forum said it might fit? Thanks!
Old 02-19-2005, 07:39 PM
goober35's Avatar
Why would u want to put an ls6 in an ls2 car. Unless you are going the other way. But yes the pan will bolt right up.
Old 02-19-2005, 07:42 PM
Speedpup's Avatar
Going to put the LS2 pan on my LS6 for better baffles it supposedly has for track use in my Vette. Thanks? Any idea on the price?
Old 02-19-2005, 07:45 PM
goober35's Avatar
MM witch ls2 pan. There is 2 out there. The one on the GTO and the one on the vette witch i asome you are talking about. As for price i have no idea. If you get it from GM it wont be cheap.
Old 02-19-2005, 07:54 PM
Speedpup's Avatar
found in the other LS2 section part # and 366 for the price. Thanks!
Old 02-20-2005, 12:35 AM
racecar's Avatar
What information do you have on the LS2 pan being better for road racing?
I am building a LS6 motor for a C5 road race car and I was just looking at Accusump systems tonight. I don't really want to add the extra weight and a check valve etc. If a LS2 pan is better, that may do the job.
That's a great picture of your car Speedpup. I have only had my C5 on the track two weekends with the LS1 motor so I really don't know what kind of oiling problems I am going to have. Do you have any oil pressure drop off while racing??
Racecar
Old 02-20-2005, 07:05 AM
Speedpup's Avatar
I have an accusump I already smoked a motor. tranny, and rear in one horrible event. I have seen it drop. Tranny and diff coolers also. Info was in a GM article but someone said it holds 1 qt less now.
Old 02-20-2005, 11:38 AM
Lvmyz28's Avatar
The LS2 oil pan holds less because of the better baffles in the pan. Yes it will fit on the motor but I don't know if it will fit in the car! Also remember the LS2 is a dry sump system so you might have some problems trying to get your oil pickup to work right if at all!
Old 02-20-2005, 01:55 PM
Poltergeist's Avatar
The LS2 is a normal oil system, the LS7 is the dry sump. IIRC
Old 03-03-2005, 08:55 PM
robin427's Avatar
Will the LS2 pan fit on the LS1? My oil pan has a slight leak in it and might not be repairable
