where can i get a unported ls6 pump
Old 02-21-2005, 06:38 PM
LS1_PNYTAMR's Avatar
Default where can i get a unported ls6 pump
seen plenty of these 120$ ported ls6 pumps... but i heard there wasn't much actual porting done, nothing my 3 dremels and air grinder couldn't take care of if it need even be done.. i also heard they can be had for 50-60$... not like im running a t-rex cam.. prolly going some in the 224-lower 230's range.. so a unported ls6 pump, and the ls2 timing chain i got should be plenty better then stock for my application im guessing. not trying to cut corners really, just trying to do the job right and save a lil cash
Old 02-22-2005, 08:56 AM
GuitsBoy's Avatar
I think SDPC has em for under 80, maybe someone else has them even cheaper? I too have heard about them going for $60.
Old 02-22-2005, 11:40 AM
8-Pack's Avatar
Yeah i would try GM parts direct
Old 02-22-2005, 03:50 PM
BB
BB's Avatar
Is it really different from the LS1? If yes where is it different?
Old 02-22-2005, 04:07 PM
GuitsBoy's Avatar
the ls1's are not uncommon to fail and kill a motor. The ls1 pumps design allows the bypass to get stuck in its bore in the open position allowing oil to just bypass.
Old 02-22-2005, 04:18 PM
01_SuperSlow's Avatar
you'll find them for about 60 bux at gmpartsdirect.com
Old 02-22-2005, 10:34 PM
Mike94ZLT1's Avatar
01-02 already come with an LS6 oil pump. The part numbers are the same.
Old 02-23-2005, 01:09 AM
is this true? so there is no need to change my pump then.. anyone else agree with this?
Old 02-23-2005, 01:28 AM
Ben01C5's Avatar
I would only change it depending on mileage.
Old 02-23-2005, 02:05 AM
hows 40k sound?
Old 02-23-2005, 07:51 AM
GuitsBoy's Avatar
01 and 02 did come with the ls6 oil pump. The replacement part number has now changed to point to the ls2 pump, although nobody has touted any new benefits of the new ls2 oil pump yet, atleast not that ive read. Unless youre going to install a ported or shimmed oil pump, you may as well leave your pump in there with 40K. if it were 60K id start thinking about it. At 80K it wouldnt make any sense not to replace it. If youre happy with your pressure, why fix what aint broke...
