opinions on h&c for my 427
Old 02-21-2005, 07:09 PM
Phoenix H.O.'s Avatar
Default opinions on h&c for my 427
i have a 427cid and i bought the h/c that were recomended to me which were 242/250 .612 .619 114 and mti stage II r heads what do you think?
Old 02-21-2005, 07:59 PM
DavidNJ's Avatar
Surprised you did all that without a head and cam! Should be fine. Some other head may be a little better, however you will probably never notice.
Will it pass emissions? Does it need to?
Old 02-22-2005, 08:58 AM
i'm not worried about emissions or any of that. that is the cam that they recomended and gave me with the shortblock and i already had the headss and didn't wanna spend the money on new ones.
Old 02-22-2005, 09:17 AM
C_Williams's Avatar
I think a set of AFR 225's and a 239/243 on a 114.
Old 02-22-2005, 09:26 AM
NumberOneSled's Avatar
Maybe send the heads back to MTI so they can upgrade them to a stage 3?
Old 02-22-2005, 10:45 AM
FigsZ28's Avatar
Send the heads back to MTI to upgrade them to a stage 3 head, along with opening up the combustion chamber to accept the larger bore on the motor, as I remember you saying that they were originally on your 346. Cam wise you should fine, id personnaly go a bit bigger
Old 02-22-2005, 11:38 AM
6 Second Club Moderator
LASTLS1's Avatar
If I were you BEFORE you put your new heads on. Check your sleeves and deck surface. I can't seem to get one from them that doesn't leak coolant! It sucks to keep taking the motor in and out to keep repairing the block. Make sure to check the deck surface! Trust me. Good luck.
Old 02-22-2005, 11:52 AM
Lafngas98Z's Avatar
I would slap a set of the new All Pro heads on there!
Old 02-22-2005, 02:11 PM
MUSTANGEATER's Avatar
Me 2... they got a small chamber design done the other day. Can't wait to get my set...
Old 04-29-2005, 10:08 PM
BUZZ1's Avatar
Default mti
I ahve MTI 427 with stage 3 heads. Put down 555 rwhp
Old 04-30-2005, 09:27 AM
slow trap's Avatar
yeah definitely send back to mti and atleast have the chambers opened up to accept the bigger bore and unshroud the valves.stage 3 would be good also .
Old 04-30-2005, 09:45 AM
Brian Tooley Racing's Avatar
In my experience with big inch engines and heads, a 4.8/5.3/5.7 head can't hardly be opened up enough to feed the engine. We always run a LS6/6.0/AFR with at least 230cc port volume. We have seen 50 RWHP between a 225cc 5.7 head (300 cfm) and a 238cc 6.0 head (340 cfm). If you can't afford heads now, don't spend ANY money on the ones you have, you will not be happy long term. Put em on and run em till you can afford what you want. And the block issue? Do some research!
