Can anyone spare some HPTuners logs?
Old 02-21-2005, 08:17 PM
Another_User's Avatar
Default Can anyone spare some HPTuners logs?
I am not really too particular about what they have...maybe some cruising and idle w/spark, MAP, dynamic airflow? IAT is always nice too... I just want some logs to compare some of mine to. Some stock (no cam) vehicles would be pretty neat-o too. Shoot an email to someoneelse@adelphia.net? I would really appreciate it! It would help me compare what the PCM is seeing on other vehicles compared to mine...I always share my findings...
Old 02-21-2005, 08:33 PM
WS6FirebirdTA00's Avatar
i can send you some of mine, but only if you help me figure out how to adjsut WOT timing lol. ill send it once i get my files fixed though
Old 02-21-2005, 08:44 PM
That's easy. Run some logs and see where your dynamic airflow g/cyl is at WOT. It should be everything .64 g/cyl and above.
Old 02-21-2005, 08:51 PM
ok and then say if i wanted to change from 3000-6400 rpm then from .64 down i would change it all accordingly? i see there is a huge dip in the graph where it goes down to 23* is it like tha tfor a reason??
Old 02-21-2005, 09:07 PM
sent it to you, now i am still starting the tuning, and my maf is not plugged in yet but maybe this will give you something you need?
Old 02-21-2005, 09:11 PM
There are many theories regarding those "dips". I think it was to cut back torque (and horsepower). At WOT I run 28 degrees of timing straight across from like 1800 rpms or something...I have to go look to be sure, but from right about that rpm on up. I actually smoothed down the one point that hit 29 degrees. A lot of people are running about 28 degrees (some go in the 30s, but that seems like a bit much for me) at WOT. Just take it easy and watch for KR before you go too crazy with the gas pedal and you should be fine.
Old 02-21-2005, 09:13 PM
I will look them over. I am sure I can find something useful out of just about any log. I have hundreds of my own, but I need others for comparison. Thanks for the logs!
Anyone else, my email box is always open!
Old 02-21-2005, 09:18 PM
can you email me your bin so i can see your timing table? you just change the high octane right? yeah the biggest thing i look for is kr, i had a problem with it before so my eye is really on that, i dont want to deal with that anymore
Old 02-21-2005, 09:21 PM
You can get my BIN at Horist's site. www.horist.com/hptuner
It's the 98 F-body tune with a full page description of what I changed. I you need some other stuff I have many (many many) other BINs I have worked on, but that was my first MAFless that I was satisfied enough with to post. The spark table has my WOT changes.
Old 02-21-2005, 09:22 PM
yeah i just found it, thanks now i see what you are saying. do i need to change any other tables??? or just high octane?
Old 02-21-2005, 09:26 PM
Ok. I emailed it to you too. I copied my high octane over my low octane. You still get normal KR, but none of it sticks. Whether or not you go that route is up to you. Some people copy the high over the low and just remove a few degrees just in case. I just watch my logs and tune out any KR that keeps popping up.
Old 02-21-2005, 10:56 PM
Any other logs are welcome! Thanks to everyone who has "donated" so far!
Old 02-22-2005, 09:01 AM
Scooter70's Avatar
I'll send you something that I ran last fall before I had to put the car down for the winter. I'd be interested in any comments you have on the state of the tune. April's coming soon, so I need to get back on top of things before cruising time starts again.
Old 02-22-2005, 06:44 PM
TTT...you can never have enough logs...
Old 02-22-2005, 07:11 PM
i got me another from tonight if you want it lol
Old 02-22-2005, 07:43 PM
The more the merrier.
Old 02-22-2005, 07:59 PM
SScam68's Avatar
I have a few that I have collected.
Almost stock, i.e. lid and then bolt on as well. Got a few recent logs in trying to get my VE dialed. I log on my way to work but unfortunately I go up in elevation about 3000ft and its hard to establish any kind of a baseline. Anyways, if you're interested I'll shoot those over to
Old 02-22-2005, 08:16 PM
Scooter70's Avatar
You've got mail.
Old 02-22-2005, 08:45 PM
Sweet.
Old 02-22-2005, 09:18 PM
SScam68's Avatar
you have mail
