what did you use...?!?
what did yall use (i know it's a 10mm bolt) to get the intake manifold off...i just got finished replacing the oil pressure sending unit and i bet it took 15-20 minutes just to get the farthest back right side bolt out...is there a small extension or something...it would have gone by faster if i could use like a 1in extension (which i did not have)...it prolly took 2 hours to do this...but then again this is my first time doing any "internal" work...whatever it was a little harder than i thought it would be...
oh and btw my hands are cut up and swollen from scrapping against the cowl and whatever else was in there...i guess welcome to the life of working on an ls1 f-body...
the back-most 4 bolts are a PITA... like was said above, a 1/4 drive with a deep socket worked well for me. Putting a little tape on the bolts to hold them up makes sliding the intake off the block MUCH easier than trying to hold them up by hand...
I used a 1/4 inch socket with a 3/8 to 1/4 adapter, it gave that little extra you need to get down there, and that with a stubby ratchet. This works great, as for the tape, yep that is the only way to keep the bolts up!
