Nitrogen filled tires
Old 03-01-2005, 08:46 AM
Tommy's dad's Avatar
Default Nitrogen filled tires
I have seen this offered at Dunlop tire store,nitrogen instead of pump air.has anyone done this?Any mileage,tire wear benefits noticed?
Old 03-01-2005, 10:25 AM
WhiteSSP's Avatar
Lots of road racers do it, IIRC its because nitrogen is a tad lighter. I may be wrong though.
Old 03-01-2005, 11:58 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
The reason people put nitrogen into tires, especially race teams is due to the expansion rate due to temperature of nitrogen vs. air. Nitrogen is dried so it contains very little water which is what causes the air to expand contract with temperature.
Not worth the issue and hassles unless you are concerned about the exact tire pressure.
In racing a 1 psi change makes a big difference when handling at 100+ mph is concerned.
Check your tire pressure weekly (or monthly) and you should be fine.
Old 03-01-2005, 12:11 PM
GM Muscle's Avatar
Exactly. I noticed a local tire place pushing nitrogen to everyone, I can only imagine some of the reasons they come up with to try and sell it to the average Joe. I guess they have to try and justify the $6K the spent for the pump station.
ZEEMAN's Avatar
when purchasing my tires i was told all the same things and it also helps out if u have chrome rims. because the moisture could eat away at the chrome after a while. i think the guy might have been bs'n me to get more of my money.
Old 03-01-2005, 12:15 PM
BTLFEDSS's Avatar
Suppose to help stop oxidizing on aluminum wheels where the bead seal ,my skinnies are nitrogen filled
BTLFEDSS
Old 03-01-2005, 12:50 PM
Kleeborp the Moderator™
MeentSS02's Avatar
So it will eat at the chrome huh? On the inside of the rim? Where no one can see? Where rims most likely aren't chromed anyway? It is amazing what people try to sell these days...
Old 03-01-2005, 01:27 PM
GM Muscle's Avatar
BTLFEDSS
But when aluminum oxidizes it forms a hard clear layer at the surface and the aluminum won't break down, right?
Old 03-01-2005, 02:07 PM
ArcticZ28's Avatar
whoooo whippets on wheels whooooo!!!
Old 03-01-2005, 02:45 PM
MyersRacing's Avatar
It keeps stagger exact when racing ovals, and doesn't swell as much like guy mentioned before, we use to use when racing karts but their is no need for it in a street tire.
Old 03-01-2005, 03:27 PM
Thanks for the info,I wasn't planning on doing it unless I got enough positive feedback.But it sounds like it's just a moneymaker for Dunn tire
Old 03-01-2005, 05:38 PM
Phoenix 5.7's Avatar
it would be a PITA if the tire was low, then you would have to go back to the tire place to get it filled, too much trouble for the street.
Old 03-01-2005, 08:36 PM
Mike98WS6's Avatar
For what it's worth. I would stick to good 'ol air. Besides, it's free.
Old 03-02-2005, 06:34 AM
UNDER PRESSURE MOD
Well, to maximize your 'air', make sure the compressor you are using has a good dryer system on it. That way you are introducing a lot less moisture to your tire. Try and avoid the gas station air stations as they don't have any dryers on them. To test this, spray a little air over your hand and see how many droplets of water form on your skin.
Old 03-02-2005, 07:15 AM
BTLFEDSS's Avatar
Well not sure on the oxidizing thing thats just what the guy told me,it was free nitrogen fill and mounting&balancing because when i ordered 165r15 they were suppose to be there the next day and it took a week1/2 to get them.The guy said he'd give me these free for not being after driving to get the tires and callin for about a week
BTLFEDSS
