Race Car For SALE,or Possible Split Up
http://www.picturetrail.com/BADBLUESS
THIS CAR HAS 8'S IN IT ALL DAY WITH SOME WEIGHT LOSS
BADBLUESS FOR SALE $24,000 OBO
LME BUILT 408ci. LONG BLOCK
-Wiesco nitrous pistons-
-Hell Fire rings-
-Lunati Pro Billet Connecting Rods-
-Clevite Rod Bearings-
-Federal Mogul Main Bearings-
-Lunati 4in. Crank-
-Comp R Lifters-
-Jessel SS Series Rockers-
-Stage 2 Heads Flowed 310cfm@..600 Lift-
-MTI Z1 Cam specs- 236/236-585/585-112 Lobe-
-Beck Sheet Metal Intake With Direct Port-
EXHAUST COMPONENTS
-Kooks Stainless Steel 1 7/8”x 2”x 3.5” collector-
-Stainless Magna flow Oval mufflers-
TRANSKING SPORTSMAN GLIDE
-Pro Trans Brake-
-1.76 Factory Gear Set-
-Turbo Spline Hy-Tuff Input-
-Red Clutches And Kolean Steel-
-Steel Clutch Hub-
-Kevlar Band-
-Dual Ring Billet Servo-
-Needle Bearings And Teflon Seals-
-Jig Trimmed Factory Case-
-Deep Alum. Pan-
-Rated To Hold 1200hp-
-Circle D Nitrous Converter 4000rpm’s on The Brake-
-Drive Shaft Built by North West Drive Train-
STRANGE 9in. REAREND
-Full Spool-
-Strange 3.55, 3.73, 4.56 gears-
-35 Spline Axles-
-5/8” Wheel studs-
SUSPENSION
-BADZ Fully Adjustable Control Arms, and Panhard rod-
-BMR Extreme Duty Torque Arm-
-Wolfe Anti-Roll Bar-
-Hotchkis Subframe Connectors
-Hals Adjustable Shocks On All Four Corners-
-Hotchkis Drag Springs In The Rear-
CHASSIS
-6in. Mike Moran Prostock Hood-
-Certified Custom Built 10pt. Roll Cage-
-Cage Professionally Painted,Then Clear Coated -
THE PRO’S THAT BUILT THIS CAR
HPE, AND CREW
OUTLAW RACE CARS
-Hell Fire rings-
-Lunati 4in. Crank-
-Comp R Lifters-
EXHAUST COMPONENTS
-Pro Trans Brake-
-Steel Clutch Hub-
-Kevlar Band-
-Deep Alum. Pan-
-Full Spool-
-35 Spline Axles-
-5/8” Wheel studs-
SUSPENSION
CHASSIS
HPE, AND CREW
OUTLAW RACE CARS
Dude, that car is absolutely awesome. $24,000 should be no problem for someone who knows the deal. That is the best looking cage I've ever seen.
Good luck man, not that you're gonna need it.
if you get down to splitting it up, let me know what you'd like for the intake manifold and fuel rails and possibly the hood as well. that's a damn nice cage, who built it? seems like it's a tad bit more than what most have for a 10 or 12 pt. what is the cert on that?
agreed john, the cage work looks impeccable (sp?) it looks awesome, my cage should be done soon, it'll be similar. i actually took pics of that one over to my builder for him to work off of. mine will include funny car cage though...still very interested in the hood once you see this badblue...let me know. good luck with the sale.
