Motor from the top?
Old 03-10-2005, 10:56 PM
HAMRHEAD's Avatar
Default Motor from the top?
All the searches I've done on pulling the motor it seems everyone pulls it from underneath. Anyone pull it from the top in their home garage (without a hyd lift)? I got the heads, intake, headers all of so there is nothing but a shortblock left and I want to pull it to work on it. Has anyone done this? How did you do it? I just want to know the best way to pull it from the TOP!
Old 03-10-2005, 11:05 PM
Tiger2o69's Avatar
I think jrp did...
Old 03-10-2005, 11:06 PM
Tiger2o69's Avatar
https://ls1tech.com/forums/showthrea...+motor+jrp+top
https://ls1tech.com/forums/showthrea...ight=jrp+motor
tell jrp to fix his pics...
Old 03-11-2005, 10:28 AM
1999T/A's Avatar
Been there , done that , got the T-shirt . Its easy to pull from the top provided you pull off the accessories and such . I pulled it with a wooden A-frame setup (looks like an oversized childs swing set), put it back in with a cherry picker borrowed from a friend . If you have any specific questions , feel free to ask .
Old 03-11-2005, 10:45 AM
HAMRHEAD's Avatar
About how much does a shortblock weigh? A stock LS1. What's the hardest part of pulling it? Is there anything that sticks out in your mind as a pain in the arss!
Old 03-11-2005, 11:15 AM
jerflash's Avatar
i pulled mine from the top and it was easy
put one end of the chain on the upper most bellhousing hole on the pass side(not the middle hole) and put the other end on the front driver side of the block and make sure you out the cheery picker on the right chain link to give you the right angle to get it out...should come out no problem becasue thats how i did it
came out easy
Old 03-11-2005, 11:24 AM
1FST99Z's Avatar
not to hard to do. just make sure you have all of the accessories off and a cherry picker would be a great tool
Old 03-11-2005, 11:32 AM
Unaffliated Racing's Avatar
I can pull a complete motor(less intake and valley cover) from the top with a modified engine tilter I made. It bolts where the valley cover goes and makes things easy as pie!
Old 03-11-2005, 11:35 AM
Justin99TA's Avatar
Yanked and installed my longblock from the top with the tranny still attached. Didn't even have to take the hood off. Its easy just pull the powerstearing pump, radiator, and ac and your game
Old 03-11-2005, 11:37 AM
Boostaholic's Avatar
I pull mine from the top and put it in the top all the time.
I can get it in and out with oil pan, trans, heads.
Old 03-11-2005, 02:16 PM
Derek98z's Avatar
damn, this might be the way I go. If you leave the tranny on, where do you bolt the chain?
Old 03-11-2005, 02:28 PM
HAMRHEAD's Avatar
As easy as this sounds why is everyone always talking about pulling it from the bottom?
Old 03-12-2005, 04:34 AM
kendo347's Avatar
Did mine from the top. Took about 6 hours.https://ls1tech.com/forums/attachmen...id=26929&stc=1
Old 03-12-2005, 05:37 AM
Shoulder Shaker's Avatar
Do anyone have any pic of them pulling the engine and trans from the top?
Old 03-12-2005, 06:19 AM
Viper's Avatar
On my website
