what do you all use to polish stainless?
Originally Posted by dragonZ28
blue magic is still the best stuff ive found over the years of trying various polishes.
I also like master formula. very easy to use...but doesnt seem to do much work. seems like it works better to keep newer rims looking new. I only use that on my alumastar 2.0's as it is non abrasive.
interestingly enough...last night i decided to polish up the draglites for my camaro that are sitting in the basement for the winter. They werent in terrible shape but needed some work. i started with master formula but they didnt look that good when done. So i went to the blue magic and it worked a lot better...came out looking new. I then finished them off with master formula.
So i guess how much work needs to be done calls for the appropriate polish.
My last winter project was to polish the aerospace brakes on the stang. i used a dremel with polishing bits. I started off with the most abrasive polish i could find (eagle one) and went over them, then used blue magic, then used master formula. They ended up being more shinny than my brand new alumastars.
