Forged Piston's
Old 03-15-2005, 07:55 PM
HellRaiser's Avatar
Default Forged Piston's
This might sound stupid but I was wondering if it's possible to put in a set piston's without doing anything else to the block. Like machine work or what not. Say forged piston's and ARP rod bolts?
Old 03-15-2005, 09:18 PM
c5jim's Avatar
The answer is no. !!!! I just finished a stock Mahle piston to a Forged Mahle piston last week. A stock (M) piston weighs 434 grams and a forged (M) piston is 382 grams . That is 14.86 ozs that has to be removed off of the crank bobs. I had my whole assembly balanced and they drilled the crank bobs to offset the weight difference.
C5-JIM
Old 03-15-2005, 10:12 PM
Restricted User
CAT3's Avatar
There are ppl that have done it, not sure on their success or problems. s far as balancing it out, the factory crank probably needed to be balanced anyway, I dont see why you take off crank weight due to piston weight changing, unless the stock rotating assemble was off balance.
