These cars are a stupid piece of fock!
Old 03-16-2005, 08:07 PM
Tech's Avatar
Default These cars are a stupid piece of fock!
I have tick that will NOT go away. I've replaced pushrods, lifters, rockers, rocker arm bolts and pedistals, spark plug wires, spark plugs, exhaust manifolds (headers), exhaust manifold gaskets, and intake manifold. The entire top half of the engine has been apart and back together and the damn thing STILL ticks. I'm ready to buy a damn Mustang. </rant>
Old 03-16-2005, 08:12 PM
HitmanLSX's Avatar
how do your belts look? tensioner pulleys? do you still have your AIR pump and tubes attached? if so did you check the check valves?
Old 03-16-2005, 08:22 PM
That's what she said...
TheBlurLS1's Avatar
i have the EXACT same thing going on. i just put in new comp 850 lifters and chromoly pushrods. its kinda dishearting isnt it?
what kinda oil pressure do you have? i'm beginning to think that i have bearing problems or somthing.
you can take both belts off and run it once it starts ticking to diagnose the belts/pulleys. take one off at a time and maby you can isolate the problem a little easier.
Old 03-16-2005, 08:49 PM
BLUEBALLS ZZ's Avatar
rod bearing could be it. had done that chase before on a car.
Old 03-16-2005, 08:56 PM
SLowETz's Avatar
My money is on the POS air tube check valves. If you want to keep your AIR system operational and lose the ticking....get some thin guage sheet metal....cut two pieces to match the AIR tube gaskets. Drill a hole in each piece ~3/16" and sandwich one between the air tube and gasket. This will keep from blowing out/burning up the check valves. Or..... get rid of the AIR system
Old 03-16-2005, 09:09 PM
Tech's Avatar
AIR system is gone. I'm way past the easy stuff.
Oil pressure is just under 40 at idle.
No metal in oil since I've owned it (only about 15k). Car now has 78k.
Old 03-16-2005, 09:11 PM
Beast96Z's Avatar
Prolly just the o-ring on the oil pump tube. Almost all LS-1's tick, it's just there nature.
Old 03-16-2005, 09:16 PM
Tech's Avatar
I've worked on many LS1 cars. Never had problems like I do with my own. I chased around false knock on my 95 Hawk just like I'm doing with this tick.
Old 03-16-2005, 09:37 PM
prostock_bigblock's Avatar
Never seen this kind of issue before.....mmmmmm
Old 03-16-2005, 10:07 PM
YTRY5.0's Avatar
Maybe its a bomb!!! LOL
Old 03-16-2005, 10:27 PM
Beast96Z's Avatar
Do I sense sarcasm?
Old 03-16-2005, 10:33 PM
white2001s10's Avatar
Upgrade your stereo system for louder volume.
Old 03-16-2005, 10:44 PM
hoserack's Avatar
Take a Xanex and drive the bitch.
Old 03-16-2005, 11:05 PM
Gloveperson's Avatar
O-ring is my guess.
You can buy a mustang and be slower (sans terminator), or deal with a tick
Old 03-16-2005, 11:12 PM
Tech's Avatar
I will NOT deal with the tick. It's personal now.
O-ring doesn't make sense to me. Stock oil pump. Plenty of pressure. I've already gone on wild goose chases.
I have a 2k stereo in my car (MB Quart) and it's unhooked because THAT has a gremlin in it too.
Old 03-16-2005, 11:19 PM
You ruled out Piston Slap right?
Old 03-16-2005, 11:20 PM
Tech's Avatar
I have piston slap but it goes away after the car is warm. Completely different noise. Piston slap has more of a tap/knock/slap sound. This is a tick.
Old 03-17-2005, 01:01 AM
CATDIESEL's Avatar
injector tick?
Old 03-17-2005, 02:00 AM
ls1 1990 VN's Avatar
our farmers drench anything with tics, maybe a good soapy wash and a bloody good redline thrashing to take out the frustration
Old 03-17-2005, 02:12 AM
Nate_Taufer's Avatar
catdiesel is probably dead on...the injectors in these cars are very noisy. I would almost bet that it is your injectors.
Nate
