can I change out my 98 computer??
Old 03-19-2005, 06:31 PM
GarrettWs6's Avatar
Default can I change out my 98 computer??
just a thought, I really want to tune my car with a mail order tune from predator, but cant cuz its a 98.
my question is, can i and would it be practical to upgrade to a 99 or newer computer?
Old 03-19-2005, 07:08 PM
monodax's Avatar
Honestly you would be better off using a different tuning solution other than a predator and keep your 98 PCM. Do some searching on the forums for alternatives and suggestions.
Old 03-19-2005, 07:42 PM
stone4779's Avatar
The harness' are different than the '99+ so I dont know.
I have no idea if it's a matter of just splicing the wires together, etc but my gut says no.
HPTuners I believe supports '98s, and is only a little more $$...
Someone will chime in, I hope...
Old 03-19-2005, 10:09 PM
RyanA's Avatar
Couldn't you just re-pin the PCM plugs? If you had the pinout on the 98 and the 99-02 PCM's you should be able to go pin by pin and change the ones that are different. Sensors are pretty much the same on them as we put a 2000 engine in a 98 car and reused the 98 harness and PCM.
Ryan
Old 03-19-2005, 11:05 PM
stone4779's Avatar
Ryan
Didnt think of that...Im pretty sure it would work...
Only thing is, if there's a couple things that arent used on the '98, they'd have to be disabled in the PCM to keep **** from going nutty, or maybe it'd just cause and SES light, dunno...
Theres got to be someone who's done it...
Old 03-20-2005, 02:46 AM
slow's Avatar
https://ls1tech.com/forums/showthrea...highlight=1998
i would not choose to make this changes, Especially just so you can use a predator
Ryan
Old 03-20-2005, 03:25 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
forget predator. get hp tuner.
brad
Old 03-20-2005, 03:27 PM
stone4779's Avatar
brad
Old 03-21-2005, 12:10 AM
wait4me's Avatar
if you want to do that swap, ill trade you your 98 computer for a 99-02 computer strait up to help you out. jessebubb@yahoo.com
Quick Reply: can I change out my 98 computer??
