.093 inch N2O Jet in NX?
10 second playa
I was looking at a race class that allows LS1 small blocks to run EFI and a single stage of N2O with a single nozzle.
The maximum size N2O jet you can run is .093 inch.
I have a NX kit. What size NX N2O jet is equal to .093 inch?
Thanks in advance.
Thanks in advance.
A NX 93 jet = .093 inches
Thanks in advance.
Thanks in advance.
10 second playa
I heard that jets from different companies are not the same.
Is that standard, that the number on the jet is the decimal equivelent?
Thanks
10 second playa
Originally Posted by 5.8litrels1eater
From memory, that's about a 350 shot (to the wheels)
10 second playa
Sorry, I meant 250 to the wheels, mistype
Thanks, you still knew more than I did. I usually run a 100 shot.
I only use it on annoying pests!
10 second playa
If you use larger solenoids like the NX Pro Power it will be a 300 Shot.
(due to the larger oriface)
Thanks Dave
