cooler size??
cooler size??
I was wondering what size cooler would work for my application.... TCI 10" USF 4000 with 3.73 gears and I drive minimal city miles (30 weekly). The transmission is a tci th400, also what size coolers is everyone else running and what is the application?
thanks guys
thanks guys
i am haveing converter put on soona dn i am going to be running the 24,000 gvw B&M with a vig 3200. in say run the biggest, heat is what kills a lot of trannis so the bigger the cooler the better.
High on diesel fumes
I don't think you want to to be too cool. The tranny fluid has an optimal temperature range, and if you go below that it will be too thick to protect properly. Not sure what the range is, but something to watch out for. Some of the coolers out there are thermal drop coolers, meaning that the thicker fluid bypasses the heat exchanger until it heats up and thins out enough to drop into it.
