So my valves and pistons must've fell in love
Old 03-23-2005, 11:31 AM
mr2guru's Avatar
Default So my valves and pistons must've fell in love
I am in the middle of a H/C swap and found their affair. It had to have been from a SERIOUS mechanical overrev when I missed 4th one time. I rolled the pushrods and their as straight as can be. Don't know about the valves but I'm not concerned. The car sounded completely normal so I don't suspect any shortblock damage.
Oh the humanity...the carnage....
Attached Thumbnails So my valves and pistons must've fell in love-kisses.jpg
Old 03-23-2005, 11:47 AM
SStheBest's Avatar
Old 03-23-2005, 11:49 AM
Boostaholic's Avatar
Have you done comp checks on your cylinders? I bet you have valves that are slightly bent and leaking pressure out, sometimes its hard to see a small bend.
Old 03-23-2005, 11:56 AM
mr2guru's Avatar
Nah, I've got new heads anyway....I'll do a baseline comp check after running in the new combo though.
Old 03-23-2005, 12:11 PM
Oh with new heads you should definantly be good to go!
Old 03-23-2005, 12:31 PM
02Z06man's Avatar
AFR-AFR-AFR-AFR-AFR-AFR-AFR-AFR-AFR-AFR-AFR
Old 03-23-2005, 12:32 PM
777's Avatar
good thing no serious damage was done...
Old 03-23-2005, 01:17 PM
Or ... Is it bad? Breaking something is always a good excuse to spend more money1!!
BLASTER's Avatar
Looks like the pistons are already notch for you. LOL Might as well fiinish the job on the others.
Old 03-23-2005, 06:14 PM
soundengineer's Avatar
dont forget...while the heads are off...at a minimum...take off the bur from the marks the valves made
Old 03-23-2005, 06:43 PM
mr2guru's Avatar
Of course, of course.
I may end up flycutting the pistons anyway. From every report the X1 cam is close. I'll see how close when I clay it.
