So my valves and pistons must've fell in love
I am in the middle of a H/C swap and found their affair. It had to have been from a SERIOUS mechanical overrev when I missed 4th one time. I rolled the pushrods and their as straight as can be. Don't know about the valves but I'm not concerned. The car sounded completely normal so I don't suspect any shortblock damage.
Oh the humanity...the carnage....
Originally Posted by Boostaholic
Have you done comp checks on your cylinders? I bet you have valves that are slightly bent and leaking pressure out, sometimes its hard to see a small bend.
Originally Posted by soundengineer
dont forget...while the heads are off...at a minimum...take off the bur from the marks the valves made
I may end up flycutting the pistons anyway. From every report the X1 cam is close. I'll see how close when I clay it.
