quick, motor mount install question
i was installing the prothane motor mounts, and i forgot which way the "nub" faces, is it below the long 18mm bolt, or above it?? The reason I ask is because i did the driver side fine, and when doing the passanger side, the holes did not line up with the pedestal. I had the nubs above the bolt (thats what the people at prothane told me) but it did not seem to line up with the bolt.
Thanks for the help guys
jimmy
jimmy
Found these pics for ya.
http://community.webshots.com/photo/...03952349slDOlt
http://community.webshots.com/photo/...03952503Tvlgoo
Basically....the end that had the two rivets goes down. Hope that helps.
