I thought AFR were the only ones with a new LSX head(guess not)
Old 03-28-2005, 12:27 AM
FASTFATBOY's Avatar
Default I thought AFR were the only ones with a new LSX head(guess not)
CHeck It out.
http://www.allproheads.com/new%20product.htm
New news to me.
David
Old 03-28-2005, 10:26 AM
OWENMUSTANG's Avatar
with 230cc runner volume and no flow specs.i don't expect a super hot response these just yet. 1749.00 is cheap though.
Old 03-28-2005, 10:54 AM
jrp
SN95 Director
jrp's Avatar
these have been around for a bit and somepeople already have them
Old 03-28-2005, 11:10 AM
Phate's Avatar
These are supposed to be a very nice head from eveything that I have heard so far.
Old 03-28-2005, 11:40 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I've heard good things about them, and they have been going on cars for over a month.
Old 03-28-2005, 04:04 PM
66deuce's Avatar
don't forget about the edlebrock ls1 head.it's not out yet,but the more companys that make heads will eventually bring the prices down somewhat.(i hope,lol).
Old 03-28-2005, 04:08 PM
SSU'S Vice Mod
sb427f-car's Avatar
If we could just convince Pro Topline (formerly pro action), DART, Brodix, and Trick flow to do it too...then we'd really see some price drops!!!
Old 03-28-2005, 04:14 PM
66deuce's Avatar
no kidding!just think back to when the SBC first came out.it took what,15,20 years or so before the aftermarket kicked in and came up with some more options.hell,the ls1 hasn't even been around for 10 years yet.
Old 03-28-2005, 04:22 PM
SSU'S Vice Mod
sb427f-car's Avatar
And there are two aftermarket heads on the maket, a third on the way, and tons of companies CNC machining and milling the factory castings. It's good to see the All Pros are offered with more deck though. I'm sure we'll see revised valve angles, splayed vavles, and really insane stuff in the next 5~6 years. Time is key. Can you think what will happen though if World starts to offer aftermarket tall deck blocks, or even one with a revised 5 head bolt per cylinder pattern?
Old 03-28-2005, 04:33 PM
JZ'sTA's Avatar
Could you imagin if checy would continue to build the F body to give aftermarket companies a better reason to make new products?
Hopefully the Vette and GTO owners mod enough to help us out. Good thing the LS1 and LS2 are so similar.
Old 03-28-2005, 05:35 PM
pdd
pdd's Avatar
tryin like hell
Old 03-28-2005, 05:52 PM
Wnts2Go10O's Avatar
maybe even a gen 3 style head for a gen 1 sbc. this jus confirms my thoughts, its the 50's all over again in terms of hot rodding.
Old 03-28-2005, 06:00 PM
Dope's Avatar
I think Dart is working on a new head. I've heard a lot about it, nothing official yet.
Dope
Old 03-28-2005, 07:00 PM
The Guy in MY 99TA's Avatar
i want to see some heads that are gunna be WICKED. So far the AFR's have been impressive but I want to see some heads that are gunna help break the 8 second naturally aspirated barrier). Thats the kinda heads I want!
Josh S.
Old 03-28-2005, 07:20 PM
66deuce's Avatar
the head their running in nascar is comparable to ours,with an 18*valve angle.well,it doesn't have replicated ports now that i think about it,but it's pretty damn good for a SBC head.and i agree,it's like the 50's all over but with a lot better technology.
Old 03-30-2005, 11:57 AM
Race your car!
JL ws-6's Avatar
Anyone out there with any dyno results on these? A complrison to a ported ls6, a set of AFR's and these would be nice.....
Old 03-30-2005, 12:18 PM
Moderator
xp3nd4bl3's Avatar
Nobody's got flow numbers on these yet? I thought some had already been shipped?
Old 03-30-2005, 12:34 PM
Red 01SS's Avatar
I have heard good things about the All Pro's
Old 03-30-2005, 07:09 PM
SSU Moderator
RyanJ's Avatar
search...specifically for "All Pro" or "All Pro Heads"...or for threads started by "427" They are cheap as-cast heads that flow 290-300cfm with a fairly large cc runner. They are more for a nice base for a all-out ported head. There is enough material for 300cc runners. They come in 65cc and a dual quench 55ish cc chambers. Thick deck...nice aluminum casting.
I want some.
Old 03-30-2005, 10:42 PM
MichLT's Avatar
Think about that statement. THE reason Pro Topline (formerly Pro Action and now owned by Comp Cams) aren't coming into market yet (if ever) is simply for that reason..No one with good business sence jumps into a market to drop prices. AFR came out with the first aftermarket head and will probably set the standard for the most profit. The All Pro head will probably prove to be superior, but after >25% of the market already has AFRs, only so many will buy All Pros, or any other aftermarket head. Edelbrock will surely be successful, because they have the marketing power, and will most likely set a new standard for value to the mass market. So, if I were to predict...I would say the community that ports OEM heads will be dead/very slow in a year, and the big companies will make their profits amongst the common consumer, and the hardcore guys will buy from companies such as All Pro. Today's market is very trendy. I may be wrong, but common sence tells me different.
