Q's on Sea Foam
Q's on Sea Foam
And YES I did do a search, but am a bit confused.
I found the Sea Foam at O'Reilly today. Question is, it was in a spray can. I read somewhere that I need the liquid. I asked the person at the counter and they said that was all they had. Did I get the right stuff?
I just shot the stuff in the throttle body throat and is now sitting. Can says to let sit for 5 minutes. I read to let it sit for as along as possible. Which is true?
Originally Posted by wrencher
Let it sit for a little while, at least 15 minutes then fire it up.
Change the oil after you do it.
Originally Posted by ZR2877
I used the spray stuff to and it did it's job. I let it set for almost an hour.
