10 Bolt Sucks?
Old 04-02-2005, 03:18 PM
WANARUNM's Avatar
Default 10 Bolt Sucks?
I KNOW THE GM 10 BOLTS OR BAD FOR BREAKING WHEN YOU START USING STICKY TIRES OR ADDING MORE POWER, BUT WHAT IN THE REAR END USUALLY TEARS UP MOST OFTEN?
Old 04-02-2005, 03:26 PM
6spdpewterZ's Avatar
The gears, carrier, and the axles.. If it breaks dont bother fixing it, get the 9 inch or the 12 bolt........
Old 04-02-2005, 03:41 PM
02SOMWS6's Avatar
I snapped a axel with less than 1000 miles
Old 04-02-2005, 04:37 PM
WANARUNM's Avatar
Ive Still Got The Stockrearend, I Have Replaced Axle. With The 6 Speed In These Cars The 3rd And 4th Gear Is Pretty Strong, If I Replaced The Gears With 4.10's Would I Lose Some Of The Top End Since I'm Gaining On The Bottom End?
Old 04-02-2005, 04:41 PM
WANARUNM's Avatar
YOU DIDNT GET THOSE NUMBERS FROM ONLY HEADS AND A CAM DID YA? WHAT KIND OF GAIN DID THE HEADS GET YOU?
Old 04-02-2005, 06:39 PM
FastLS1Chick's Avatar
Well Thursday at the track I took out my 6th set of gears 2nd carrier and 2nd stock tranny (3 weeks old). Its not going back together till my 12 bolt arrives and built tranny is done. This throwing money down the drain is done with this 10 bolt. This is my everyday driver, I am on vacation, they got a week to getter done.
Old 04-02-2005, 09:22 PM
WANARUNM's Avatar
GOOD LUCK WITH THE NEW PARTS- YOU GOT A LONG SUMMER AHEAD OF YOU!!
Old 04-02-2005, 09:35 PM
02SOMWS6's Avatar
heads and cam and SLP LT with a stock firehawk cat back.Thats with a moser 12 bolt- a ten bolt would have shot the dyno#'s even higher
Old 04-02-2005, 11:57 PM
WANARUNM's Avatar
NICE!
Old 04-04-2005, 11:48 PM
SRP
SRP's Avatar
don't think you'll be able to get away with an aftermarket carrier either, they break too. broke my eaton posi the week i installed it in 7 places on my first run at the track with it. only launched at 3k too, instead of my normal 6000 rpm.
ps. ls1's are EASY to make power out of. we just dynoed an ls1 corvette last week that made 549 rwhp and 566rwtq on a mustang dyno. add 13% for dynojet numbers. heads cam exhaust.
Old 04-05-2005, 12:59 AM
WOT
WOT's Avatar
Originally Posted by SRP
.... ps. ls1's are EASY to make power out of. we just dynoed an ls1 corvette last week that made 549 rwhp and 566rwtq on a mustang dyno. add 13% for dynojet numbers. heads cam exhaust.
And what kind of power adder? What was the displacement???
Old 04-05-2005, 08:56 AM
peteZ's Avatar
Even if you beef everything else up, the pinion support will always be a weak link. It allows the pinion to move slightly, which destroys the ring & pinion. There is a guy out there that gusseted the hell out of his 10bolt and he's had a few seasons on it running 10's. The bottom line is the 10 bolt isn't worth building unless you have some sort of 10bolt compulsion, etc.
Old 04-05-2005, 06:13 PM
WANARUNM's Avatar
What About The Stock 6 Speed In The 99's - If It Starts Grinding While Trying To Go In Gear- Is It Worth Rebuilding The Stock Equipment Or Time To Go To Aftermarket Set Ups.
Old 04-05-2005, 06:22 PM
JLMoses's Avatar
with my 10-bolt i busted the ring and pinion and the axles..... so i upgraded... hehe
Old 04-07-2005, 12:33 PM
SRP
SRP's Avatar
stock displacement, naturally aspirated. It's a road course car raced on Mid-Ohio.
Old 04-10-2005, 12:16 PM
hugger1975's Avatar
why do u use caps on every word?
and upgrade the rear to a 9' or 12 bolt.
Old 04-10-2005, 07:14 PM
WANARUNM's Avatar
Never noticed caps- nice video, better license plate though!!!
Old 04-10-2005, 11:32 PM
1fstbird's Avatar
i have never had a problem with my stock 10 bolt i run mickey thompson 26x11.5x16 et streets and the rearend is completly stock except for a set of 3:73 gears
Old 04-11-2005, 06:53 PM
hugger1975's Avatar
wow........
countdown to exploding 10 bolt..........
u are braver than most
impressive
thanx......
Old 04-12-2005, 01:47 PM
02SOMWS6's Avatar
Some auto cars are lucky and the rear will last a little longer than most but will go if it is run at the track alot.You might want to at least change your axels. I snapped a axel with under 1,000 miles on the car. I guess cutting 1.62 60ft.'s with the stock rear didn't help
