problems with converter.
Old 04-03-2005, 02:26 PM
redhotz28's Avatar
Default problems with converter.
hey guys, just finished installing a tci sf3000 converter. was wondering if any of you guys have experienced this problem: at idle rpms start jump, when coming to a stop car shuts off. seems almost as if there is a vaccum leak or something. when tranny was out i seen a vacumm-t two side were connected but one side was open, did i miss a hose or do you guys know whats going on. please any help would be appreciated.
Old 04-03-2005, 02:46 PM
strokedls1's Avatar
There is a vacuum line coming out the back of the intake. It goes off to the drivers side where it T's off. Check to make sure all lines are connected.
Old 04-03-2005, 03:32 PM
SmokingWS6's Avatar
Might need to do the idle relearn procedure.
I believe its
Disconnect battery
Turn ingntion on/off
Reconnect
start car
2 mins idle in park
2 mins idle in drive
2 mins idle in reverse
Old 04-03-2005, 09:20 PM
redhotz28's Avatar
on the t fitting there was a hose that was conncected , so are all 3 sides of the connector hooked to a hose?
