Milling 5.3 Heads...
Old 04-03-2005, 06:03 PM
BoneSS's Avatar
Default Milling 5.3 Heads...
Who has done it and what cam are you running (w/o flycutting)?
Old 04-03-2005, 08:35 PM
Jabroni's Avatar
See sig...
Old 04-03-2005, 09:29 PM
ssheets's Avatar
I was told not more than .010" with 2.02" valves and 232*@ .598" lift 0* advance.
That's what I'm running with a Futral F14 and 5.3s..well soon. They should be done in about 3 weeks.
Old 04-03-2005, 09:58 PM
BoneSS's Avatar
What is the compression of that setup? M6 or A4? What LSA? Is that what FMS recommended? Alot of questions---sorry!
Old 04-03-2005, 10:25 PM
Jimm's Avatar
I have 5.3 heads milled .016, with 2.055" intake and 1.55" exhaust valve. Running a FM11 228"/230", .576"/.595" on 112 LSA cam.
Old 04-04-2005, 01:15 AM
ssheets's Avatar
Yeah, when I talked to Futral they said with the F14 to stay with 2.02" I'm going with the F14-112-0 (232/234 .598./598) I was going to go with 2.05" intakes, but Futral and TEA adviced against it unless I wanted to get less cam, flycut the pistons or settle for less CR.
Old 04-04-2005, 10:11 PM
BoneSS's Avatar
What does milling the heads by 0.010 raise the cr to?
Old 04-05-2005, 09:39 AM
MARKSZ71's Avatar
shaved mine by .020 but i have a baby 226 226 cam on a 114
Old 04-05-2005, 04:06 PM
BoneSS's Avatar
Any ideas what the compression ratio would be w/ these milled 0.01?
Old 11-01-2005, 02:28 AM
BoneSS's Avatar
Just curious still, 5.3's milled 0.1 w/ 0.45 comets...
