True duels or Borlamouth
Old 04-08-2005, 01:57 PM
Mr. Trick's Avatar
Default True duels or Borlamouth
I plan on putting exhaust on my soon, but I am wondering If I should go with true duels or Borlamouth. I don't have LT's yet but I plan on getting them towards the end of the summer. I want something that has a real good sound and flow. What do you guys think.
Old 04-08-2005, 02:07 PM
Mr. Trick's Avatar
BTW If I go whith true duels I would like to use the Spiral flow Moroso's, I heard a car with them on ls1sounds and it sounded awsome IMO. But I already have a borla XR-1 but if I go with TD's my cousin wants to buy it for his GMC.
Old 04-08-2005, 02:08 PM
SSU's Drunk Typing Whore
Lithium's Avatar
True Duals hands down, has really good sound and flow.
Old 04-08-2005, 02:10 PM
obZidian's Avatar
the borlamouth will sound great, imo, but it will be loud. The tone is more refined then some of the t.d. but not all. Its up for grabs personally, i would go either depending on wat ground clearance you have. Boralmouth: lowered. T.D.: stock height of 1' drop
good luck!!
Old 04-08-2005, 02:12 PM
Z-286speed's Avatar
True duals and dont look back, the way those things flow, and sound, you cant beat them!
Old 04-08-2005, 08:26 PM
LS1Maniac's Avatar
Even a crappy true duals setup will sound better than any y-pipe setup in my book. You just can't beat that true duals sound.
Old 04-08-2005, 11:18 PM
kpowr82's Avatar
Hooker Cat-Back. They flow great and sound great even with LT's and an ORY. I had true duals and wasn't too happy with the ground clearance. I also plan on going lower, so it would have been a bigger problem then.
I posted a couple of times that I didn't like how the Hooker sounded. But I had a loose plug wire at the time and it made much more rasp then. I think it sounds great now, and hardly no rasp.
BTW, I had a loudmouth with the LT's before and it sounded like ****.
Old 04-09-2005, 03:30 AM
ZR2877's Avatar
True Duals all the way.
