How much displacement with 5.3 heads
Old 04-09-2005, 12:13 AM
destroyerSS's Avatar
Default How much displacement with 5.3 heads
My motor is going down hill fast so it's time for a new short block and i am wondering what CID i can get and still keep my A/S stg 2.5 5.3l heads?? I would also like to stay aluminium if possible. I'm thinking 383 but what are your thoughts? Thanks Shawn
Old 04-09-2005, 12:14 AM
BrentB@TEA's Avatar
will work well, Just spec the short block so as not to get to crazy with compression. As long as your staying with a 3.9 bore I think you will be good to go.
Old 04-09-2005, 09:10 PM
how about a 402 LS2??
Old 04-09-2005, 09:20 PM
BrentB@TEA's Avatar
If you go with a 402 I think you would be better off with a set of ported 6.0l heads or a ported ls6 head.
Old 04-09-2005, 09:26 PM
What kind of power would i be leaving on the table with a 383 with my heads vs a 402 with nice 6.0L heads?
Old 04-09-2005, 09:32 PM
BrentB@TEA's Avatar
with a 383 I think the 5.3 heads will be fine. The reason I think that is the 383 uses a stock 3.9 bore. If you go to a 402 you need to step up on the cylinder to something opened up to a 4 inch bore. You will also need larger chambers with a 402 depending on what pistons you get if you want to keep using pump gas.
