New rear, ds, and trq arm
I just got my Moser 12 bolt with 4.10's, a denny's NR DS, and a Spohn Adjustable trq arm that mounts to the chassis. I expect some increased vibration, which there is at around 70-80. But from 80 and up it gets bad. At 100+ it feels like its gonna shake apart and at 120+ it actually was so bad that it scared me enough to let off. What do you guys think it is?
I second this question. Mine feels like a fluttering underneath the car from 70 to 107, I haven't had it any higher. It's got me a little concerned.
I still have the stock DS in mine. Maybe try putting that back in to see if it changes.
Im curious to which of these parts has caused the shake. I know my car vibrates bad after 120mph with the poly trans mount, so Im assuming you are getting lots worse. Maybe a lose bolt or wrong oil. Try putting in the stock torque arm back on the car to exclude the torque arm as being part of the shake. Good luck.
https://ls1tech.com/forums/gears-axles/304836-vibration-rattle-clunk-after-swapped-parts.html
I think I'm starting with putting my BMR trans mount tq arm back and re-evaluate the rattles/noises with THAT eliminated.
