pros and cons moser 9inch vs 12bolt
Originally Posted by TXZ28LS1
what are the pros and cons. obviously our 10 bolt sucks, so anything better will do. hows ther performance for these 2 different rear ends. i figure going with the 9inch is alot cheaper?
although I've seen some intresting work post here to get 3 channel ABS working with the 9", its not really possible.. If you have the 4 channel ABS, or don't care about it, then this isn't an issue.
12 bolts : Less drivetrain loss. 3-channel availability.
9 inch. : Stonger (especially in M6 applications). Easier gear swap.
I wanted a 9 inch but ended with a 12 bolts because I have a 3-channel setup and I wanted to keep my ABS (daily driver). So far, my 12 bolts worked fine with minimal gear whine. Used to be totally silent until I started to get on it
