Best Launch Technique for Basically Stock M6 Cars
I was wondering how other M6 guys/gals get their best launches on near stock cars. I went to the track Saturday for the first time ever and my best 60' time was 2.25 . I was launching at 2K RPM's and feathering the clutch to minimize spin. I just wanted to know what the best technique for my current setup would be? Please note I am still on stock tires as well. Thanks in advance for your suggestions.
LS1TECH Sponsor
Drive around the water box, do a light spin on the tires and ease the clutch out at 1500 - 2000 rpm. No need to heat stock radials. Get some drag radials and try that for better 60' times.
Possible Scammer - Buyer Beware - Issues Unresolved
drive round the water, do a light burnout, rev it up to 2k RPMs and feather the clutch. usually good for 2.1s but i have got some 2.0 sixty foots too. on kumho ecsta supra's
Moderator
I lowere the rear pressure to 22 psi. Go around the water box & do a small burnout to dust off the tires. rev to 1200 rpm and dump the clutch as I mash the gas 2.0 60' on stock tires every time. I just bought Nitto's, so we will see how that goes soon.
It takes getting use too but I would do a quick 1K slip as I accelerate and bring the clutch up quick and then hammer down at the same time.It took a while to master it but even after the nittos I used the same technique with more RPM to keep the 10 bolt alive.I usually got 2.0 but never 1.9X on street tires and low 1.8 and a few 1.79's on nittos.
Originally Posted by GT Griller
I have friend that goes off of idle. He does a simultaneous switch lets the clutch out and mashes the gas for consistent 2.0's.
On my totally stock Trans Am, I would rev the engine to 2000 to 2500 rpm.Start letting the clutch out but let it slip a bit to keep the engine from bogging. You usually want to get a very slight squeak from the tires and the clutch should be all the way out by the 60ft mark. I found this worked to get me some 1.80 60fts and 12.80s-12.90s at the track. It took a lot of practice to get it right. I usually just heat the tires enough to clean them off.
Originally Posted by NIRVANA
Yeah I thought about driving around the water box because I know that heating up the Goodyears is pretty much worthless. I'll try that next time. Any other ideas from anyone? Also, is 1.9-2.0 attainable on street tires with a lot of practice?
