Bogging and bucking on the spray
Old 04-12-2005, 08:14 PM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
Default Bogging and bucking on the spray
Sprayed my Z06 a couple days ago with the 150 jets.Made four 0-130 blasts and the car ran great.
Parked the car for an hour and went out again.Had the bottle at 950-975 PSI,purged then hit the switch.Car bucked and bogged,lifted immediately SES flashed for five seconds than went off.Wasn't brave enough to try again.
Engine runs normal NA.Pulled all the TR6's(kinda of a bitch)and they look just as good as the day they went in.
I thought I may have ran the bottle out but I weighed it today and 21.5 lbs popped up on the scale.Bottle sat in my unheated shop all winter,filled it at Thunder Shootout last Nov.Don't know if that's relevant but I want to give all the info I can think of.
I'm a rookie and need some help.
Mod list
TNT F-2 150 jets
Dynotune heater and blaster purge
FPSS
Kenne Belle boost a pump
Timing tuner hooked up but haven't used it yet
LGM LT no cats
Stock tune
Fresh tankful of Sunoco 94
Old 04-12-2005, 10:19 PM
Nitro Dave's Nitrous Outlet's Avatar
Check the fuel pressure safety switch and see if it is cutting off and on.Also check the solenoids and make sure they are both working.
Dave
Old 04-12-2005, 10:22 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
may i ask how you managed to make 4 passes like that spraying 150 ans still have so much spray ledt in the bottle?
Old 04-12-2005, 10:44 PM
7 Second Club
10.5 Dave's Avatar
I was on the street not the track.You may be on to something,maybe it wasn't working right.It pulled like never before though,much harder than the 100 jets.It's the first time I ever put the 150 jets in.
I have only sprayed the car maybe ten times,which is my only experience with nitrous.
It sure is fun when it works.
Old 04-12-2005, 10:47 PM
7 Second Club
10.5 Dave's Avatar
Dave
Thanks Dave I'll do that.I bought the kit and most of the accessories from you last fall.I may call you tomorrow if I find myself dumbstruck.
Old 04-12-2005, 10:50 PM
ddnspider's Avatar
all i know is that no matter if i was at the track or not and i ran 4 times with the juice i KNOW my bottle would be empty!
Old 04-12-2005, 10:57 PM
7 Second Club
10.5 Dave's Avatar
Okay,I was thinking along those lines also.I just don't have much experience with the stuff.Maybe my scale is screwed up and the bottle is low but not empty.I'll try a freshly filled bottle tomorrow before I do anything else.
Old 04-13-2005, 05:45 AM
tektrans's Avatar
If you were driving around on the street maybe you fouled your plugs............I know you said you checked them, I'm just throwing out ideas.
Old 04-13-2005, 03:48 PM
7 Second Club
10.5 Dave's Avatar
I took the FPSS off to eliminate it from the equation.I suspect the fuel soleniod isn't working.
I'm going to try a couple more things.
Old 04-13-2005, 05:03 PM
7 Second Club
Phil99vette's Avatar
A couple of things..
1) Watch out fuel addatives, I tried some and it swelled the oring in the fuel solenoid and locked it up...
2) Watch bottle weight, you'd be surprised how fast you got through a bottle on a 150 shot.
3) You should have a new fuel pump in that monster
4) On a TNT 150 shot I would probably pull some timing since its more like a 225 shot
Phil
Old 04-13-2005, 08:04 PM
7 Second Club
10.5 Dave's Avatar
Phil
Bypassed the FPSS this afternoon and the car runs like it should on the hose.
Either the switch was bad our it was doing it's job.I'll verify tommorrow with FP gauge duct taped to the windshield while I spray it.I know it was dumb without verifying FP but I drove around for an hour and emptied the bottle.
Traction is an issue with the factory rubber.With the 4.10's it lights the tires up till the top of third and scratches them hard into fourth.
1 I don't use additives in any of my vehicles.
2 I emptied it today with five or six 40-120 blasts
3 If one was available I would buy it in a minute.Late 03 with returnless fuel system.Waiting on Racetronix to come out with one.
4 I'm going to try a 200 shot at the track on Fri with the CCW's and 28/10 Hoosiers slicks.Going to run the tank down to E and put five gallons of 103 unleaded in,back out five degrees of timing.I have a 427 coming in the next several weeks so I'm going to get ballsy with the stock motor.
Big thanks to Dave Diluca(Sled 28) at ARE/AUTOWORX for his assistance on the phone today.
Old 04-13-2005, 09:55 PM
SLED28's Avatar
Hey no problem bro... I like the number 4 idea
Old 04-13-2005, 10:59 PM
Z284U2TRY's Avatar
Suggestion get a window switch if you don't have one yet.
Old 04-14-2005, 06:26 AM
7 Second Club
10.5 Dave's Avatar
I have one.
