Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
garage/moving sale
Old 04-12-2005, 10:50 PM
gen 3 bu's Avatar
Default garage/moving sale
quantity at left all prices are obo, and plus shipping, local delivery can be arranged. thanks for looking
1) 333882 heavy duty casting sbc head with steam holes and recent valve job perimiter bolt vavle covers
-- $40
1) 482624 light duty casting sbc head with steam holes and recent valve job perimeter bolt vavle covers
-- $30
1) 14014416 perimeter bolt valve cover sbc head has valves, no springs
-- $20
1) 3884520 perimeter bolt valve cover sbc head has valves, no springs
-- $20
2) 14102193 perimeter bolt valve cover sbc head has minor port work on one head, no valves
-- $50/pair
2) 14101081 center bolt valve cover sbc heads
-- $40/pair
4) 14102193 sbc heads for center bolt valve covers, 2 have very low mileage stock replacement valve springs
-- $40/pair
2) used stock s-10 front coil springs with heavy duty towing package and 4.3 auto - great condition
-- $20
2) used stock s-10 front spindles - great condition
-- $40
2) used stock s-10 front calipers
-- $10
1) stock th 350 trans pan with drain plug
-- scrap yard
1) sbc 2 piece rear main oil pan stock
-- scrap yard
1) set of partially ported tpi intake runners, and ported upper plenum
-- $40
1) qudrajet 4 barrel carb
70422j2 dj1
2728
stamped by the secondary shaft on the drivers side of carb
-- make offer
1) carter afb carb
42958 k6 -- stamped by pass front mounting bolt
0-1830 -- stamped on the pass side of the main body
-- make offer
1) set of rear air shocks from a 1993 s-10
-- $25
1) rear disc brake setup from a 2001 zr2 s-10 pick-up
-- $25
1) complete set of rancho lift/lower blocks, cast iron/steel, with driveshaft correction angles, with all hardware, used @ 3 months and decided the vehicle was too high (would not fit in the garage), cost 74.99 new at jegs
-- $50
6) sbc centerbolt valve covers
-- scrap yard
2) one rear main sbc timing covers
-- scrap yard
1) set of good stock 5.7 inch 350 rods
-- $50
1) one piece rear main seal 350 sbc crank
-- $30
1) holley 750 dp without choke, works great, off of a friends 750hp 396 sbf
-- $200
1) factory vortec 350 roller cam, lifters, link bars, and spider
-- $75
2) gm 3.42 gear set
-- $40 each
both are gear sets for gm 7.5/7.625 10 bolt rear diff.
1) eaton locker from a 2001 zr2 s-10 30 spline axle 8.5" 10 bolt 15000 miles
-- $150
1) th350 needs rebuilt 6 inch tailshaft
--$50
4) 1993 grand prix wheels, good for drag radials on a gtp/bonneville
-- scrap yard
1) Open 4 Barrel Carb 2 Inch Spacer - Brand New, Never Used!
-- $20
2) 1993 Z28 Rear Rotors And Caliper Brackets - No Calipers
-- $25
***added***
s-10 reece hitch p/n 06064 3500/300 max weight
$20
hi rpm flex fan 17" blue/silver
$10
hooker 3" collectors with grafoil gasket
$20
Old 04-13-2005, 11:20 PM
indyparts's Avatar
Seen a couple of things that I may be able to use.. I will do some checking and get back with you
Old 04-14-2005, 06:54 PM
gen 3 bu's Avatar
let me know, if you get the 3.4/a4 from ls1boost you can pick up all the parts at the same time. we work together.
Old 04-16-2005, 09:56 PM
gen 3 bu's Avatar
list updated
Old 04-18-2005, 08:36 PM
gen 3 bu's Avatar
1) gm 3.42 gear set
-- $50
1) richmond 3.73 gear set
-- $100
1) zexel-torsen rear diff from a 2002 f-body works perfect 3500 miles
-- $150
-- $150
Old 04-20-2005, 08:18 PM
gen 3 bu's Avatar
*****added*****
-- $20
-- $25
Old 04-23-2005, 08:17 AM
gen 3 bu's Avatar
prices and items updated. i will be moving very soon, so help me get rid of all this stuff.
thanks
kevin
Old 04-23-2005, 11:24 AM
markymark's Avatar
what carrier is the zexel torsen for?
Old 04-23-2005, 09:30 PM
gen 3 bu's Avatar
Replied To Pm And Updated The List
Old 04-26-2005, 07:58 PM
gen 3 bu's Avatar
ttt again
Old 04-27-2005, 05:52 PM
gen 3 bu's Avatar
3.73 gears and zexel diff sold. everything else needs to go by next weekend. i will be semi-homeless for 3 weeks till i can get into the new house, and i dont have the storage.
thanks guys/gals
kevin
Old 04-30-2005, 06:07 PM
gen 3 bu's Avatar
richmond gears, zexel posi, weiand intake, and general kinetics cam sold and shipped.
Old 05-03-2005, 10:17 PM
gen 3 bu's Avatar
updated list. stuff is going to scrap yard.
Old 05-07-2005, 08:37 PM
gen 3 bu's Avatar
Unhappy
i have temporarily moved to my inlaws house. i will still visit the board, just not as often for the next couple of weeks. the list has been updated again. everything is packed away in storage, so pics will not be available for the next 2-3 weeks. you can still e-mail or pm me just please be patient.
thanks
kevin
Quick Reply: garage/moving sale
