How does a QTP Cutout work?
Old 04-20-2005, 12:12 PM
2KThunder's Avatar
Default How does a QTP Cutout work?
More specifically the switch. The site says its a toggle, so wouldnt that mean its eitehr a. open or b. closed? The site says you can run it open, closed, or anywhere inbetween. Im curious as to how you make it 'inbetween'. Im getting an LS1, and I think instead of getting a loudmouth, i'll get a quieter muffler and a cutout, so it can be really loud, or nice and quiet, and I have a Thunder Racing credit, and they sell the QTP CO. Thanks.
Old 04-20-2005, 12:50 PM
bowtieman81's Avatar
The cutout is powered by a small DC motor, and the switch basically tunrs the motor on (forward of backwards) and off. You can run the cutout totally closed, open, or anywhere in between. All you do is depress the switch until the cutout moves where you want it. Really though, you will likely have it either all open or all closed. Having it part way open doesn't really make it noticeably quieter compared to all the way open. Hope that helps.
Old 04-20-2005, 12:56 PM
2001NBMZ28's Avatar
It's a "momentary" switch - so when you take your finger off it stops the motor at whatever position it's in, and returns to the "center" position.
Old 04-20-2005, 01:02 PM
2KThunder's Avatar
Ah I see, So its 100% revolving? Or does it stop all the way open and stop all the way closed?
Old 04-20-2005, 01:15 PM
2001NBMZ28's Avatar
You have to stop it (let go of the switch) when it's open/closed - you'll be able to tell by the sound.
Old 04-20-2005, 01:50 PM
KrazyDan's Avatar
is this why you hear of them breaking sometimes? when people keep closing when its already closed?
Old 04-20-2005, 02:37 PM
LS69TA's Avatar
It'll make the motor die on you alot sooner. You can tell when it's all the way closed or open by the sound it makes.
Old 04-20-2005, 08:41 PM
Super Sport Beast's Avatar
Why would the motor die alot sooner, cuz of a cut-out???
Old 04-20-2005, 09:15 PM
1999T/A's Avatar
Hes talkin about the little electric motor on the cutout dying sooner not the actual motor in the car . . .
Old 04-20-2005, 09:25 PM
hahhaha lol my bad .......
Old 04-20-2005, 09:48 PM
LS69TA's Avatar
I have those moments myself
Old 04-20-2005, 09:51 PM
'02 SLP#686's Avatar
Gained me some time at the track
Old 04-20-2005, 09:55 PM
SLEEK00SS's Avatar
Do they make them for 3" exhaust? I have seen 2 1/2" for sale. Not 3". If so, who sells it?
Old 04-20-2005, 10:28 PM
WS-Sick's Avatar
My cutout is a 3" peice. They are a sponsor on this site I believe. Check my sig.
Old 04-21-2005, 12:01 AM
Ken@xxxxx's Avatar
yup, we have 3 inch available, any other questions or if you wanna order. Give us a call
Old 04-21-2005, 02:53 AM
transAm-98's Avatar
not to rag on QTP, they make awesome products, and electric cutouts are a fun to play with. but if i could do it all over again i wouldn't have gotten the cut-outs. they tend to leak and the motors like to work themselves lose. i've had to take them apart and tighten up the bolts inside twice now. plus the track almost always shuts me down when i try to run them open. i'm going to swap them for true duals.
Old 04-21-2005, 01:20 PM
Ant's-WS6's Avatar
Okay, here's a dumb newbie questions but if I don't ask I won't learn...1) How many are usually installed on say a T/A? Right now my system is stock but in the next week or 2 I'm going to be installing my Corsa cat-back. I am planning on getting long tubes and new Y (probably with low restricted cats - have no real need for an off-road plus if it helps with emissions a little that's a good enough excuse for me...anyway) sometime in the fall. 2) Should I wait until I get the new headers and Y or does it not matter if the cut-out is installed now and the headers and Y later?
Thanks man, any help is appreciated.
Ant
Old 04-21-2005, 02:32 PM
2KThunder's Avatar
Usually its one, behind the cat, for sound purpose, and some performance. For an all out drag car or a car with true duals its usually 2, before cats.
Old 04-21-2005, 02:35 PM
LS69TA's Avatar
There's a perfect spot on the I-pipe just under the pass. side rear seat. You also have a grommet right there to feed the cord into.
Old 04-21-2005, 02:37 PM
Ant's-WS6's Avatar
Cool, thanks guys!
Ant
