Who has dished pistons for standard bore 6.0?
Old 04-27-2005, 10:07 PM
Timberwolf's Avatar
Default Who has dished pistons for standard bore 6.0?
want dished as possible, just don't really see much browsing sponsor sites. Anyone want to narrow it down?
Old 04-27-2005, 10:11 PM
CorvetteAndy's Avatar
What stroke and rod length? I probably have them in 4.005, not sure about 4.000.
Old 04-27-2005, 10:17 PM
Timberwolf's Avatar
stock rod length and stroke. I'm just gonna boost it, and my heads are a little smaller chamber then stock, so I need to compensate by either a dish (-20cc maybe?) or a zero deck height, or both.
Old 04-27-2005, 11:55 PM
I like to see a 9.5 compression ratio with a reasonable amount of boost.
With a 70CC chamber, a standard .060 gasket, the piston .010 out of the hole, standard stroke and bore, all you'll want is a 7CC dish to put you there.
Old 04-27-2005, 11:57 PM
Timberwolf's Avatar
well, my chambers are 64cc, so would you recommend a -15cc then? I am looking at a t76 kit....
Old 04-28-2005, 10:49 AM
narcszm's Avatar
The old LQ4 engine had dished pistons, then they upgraded to flat-tops on the LQ9, if I recall correctly. But, if your're rebuilding your bottom end, maybe you don't want hypereutectic pistons.
Old 04-28-2005, 01:13 PM
Timberwolf's Avatar
I am planning to boost it, so it will likely get forged pistons and rods. just looking for good replacements with the right dish in standard bore. the block has ZERO miles on it, so I really don't want to have to go get it machined.
Old 04-28-2005, 01:37 PM
slyws6's Avatar
I used Wiseco -25cc forged 2618 pistons on a 6.0L setup with std bore.
-Sly
Old 04-28-2005, 01:38 PM
Timberwolf's Avatar
-Sly
good info. was that standard rod length too? What head CC did you use? And what gasket?
Old 04-28-2005, 02:11 PM
slyws6's Avatar
Standard rod length from what I remember, I was using Eagle H-Beam Rods. The heads were PP Stage 3 LS6 heads with 59cc chambers (from my H/C setup, reason such small chambers). As for the head gasket, I don't remember the thickness off of the top of my head but it was the Fel-Pro 6.0L gaskets you get from the auto store. The reason I used these is because I had the block cut for o-rings around each cylinder and you can't use an MLS gasket with them, I could have gone copper but then the heads would have needed receiver grooves. Anyway, sorry I'm not too much help, this engine was built awhile ago and I have since sold it to another member on this board. If my memory serves me correctly I had figured the compression ratio to be arount 8.7:1 give or take a couple tenths.
-Sly
Old 04-28-2005, 02:14 PM
Timberwolf's Avatar
thanks! 8.7 is a pretty good drop for a 59cc head. How much boost were you pushing?
do you happen to remember the part number of the pistons? I don't see ANY gen3 pistons on their site
Old 04-28-2005, 02:20 PM
slyws6's Avatar
Click this link....
http://www.wiseco.com/PDFcatalogs/AB05_chevy.pdf
and go to page 8, their website has been updated some since I have been there, it tells you the compression ratio depending on your chamber size. The ones you want are titled:
LS-1/LS-2/6.0 Truck - Reverse Dome - Turbo Duty
-Sly
Old 04-28-2005, 02:22 PM
Timberwolf's Avatar
:bow:
