WTF? My shifter(stick) just came out
Originally Posted by vince3
damn, bolts arnt there!
ill have to wait until monday to find the replacements
There probably down there. Probably rolled between the carpet and trans tunnel.
Had the same thing happen with my Hurst when I got the car.
Ripping through the gears one day I noticed alot of slop. Popped off the shifter boot and sure enough the bolts were just about backed all the way out. A little lock-tite, tightened them up and she was good to go. Soon after swapped to a B&M Ripper . After doing that I couldn't even imagine going back to the Hurst.
Haaahahaa...same thing happened to me once only with a different shifter. I thought the whole trans was wiped out or something. Use loctite and tighten the crapp outta the bolts when you reinstall.
that's hilarious...for some reason i just started laughing because i got a mental picture of some guy rowing the gears and then bam he is holding a shifter in his hands with a confused face...someone should make a cartoon...i'm sure you would get plenty of laughs...
on a serious note i'm glad you found the bolts...just put some locktite on there and you'll be set
It is kinda funny...I guess there's not much chance of danger with this problem unless you're stuck in a bunch of traffic and it happens while you're in neutral and you can't get off the road. Or unless you panic and do something stupid...
Anyway, glad no one and no cars got hurt.
i installed my pro 5.0/lss yesterday and this just happened to me. i'm in fourth and that MF just pops out and i'm coasting. it could've been ugly if i was doing the whole "left turn yeild on green" thing and just stopped in the middle of the lane. don't forget the loctite!
Originally Posted by kkkevvvinnn
the stock hurst isnt the best shifter. Id say maybe look into a pro 5.0...thats what im going to do soon even though i have the B&M ripper shifter
