high or low impedence injectors?
i found this company thatll make me Venom injectors,i just pick what # per hour i want and high or low impedence.heres what they say
"We manufacture all fuel injectors in house. We have the ability to build fuel injectors at any specified flow rate from 19 lbs / hr up to 180 lbs/ hr. Electromagnetic coils are molded with aerospace grade polymer, injection molding, copper winding, etc. all done in house at venom performance! Since we wind our own electromagnetic coils in house it gives us the ability to build low or high ohm (impedance) fuel injectors. All of our fuel injector bodies, tops, etc. are machined in house on our HASS CNC and HAAS MILL machines.
All Venom fuel Injectors come with Bushings, O-rings, and filter baskets ! Balanced and matched to increase flow rate and atomization, tolerance held within +/- 1.5% of their nominal pound/flow. Advanced polymer is used in our o-rings to insure that there is no o-ring failure. Electrical plugs are molded of aerospace grade material, and utilize Solid copper terminals to increase current flow to the electromagnetic coil. Guide pins are slightly oversized for tighter fit reducing terminal corrosion. Fuel Injectors are leak tested at three times OEM operating pressure.
Venom HP universal fuel injectors fit all vehicle make and models that are currently fuel injected.
PART
FLOW
POWER
HP-619-4, 6, 8
19 lbs/hr
up to 245 hp
HP-621-4, 6, 8
21 lbs/hr
up to 270 hp
HP-623-4, 6, 8
23 lbs/hr
up to 295 hp
HP-624-4, 6, 8
24 lbs/hr
up to 310 hp
HP-626-4, 6, 8
26 lbs/hr
up to 335 hp
HP-630-4, 6, 8
30 lbs/hr
up to 385 hp
HP-632-4, 6, 8
32 lbs/hr
up to 410 hp
HP-636-4, 6, 8
36 lbs/hr
up to 460 hp
HP-640-4, 6, 8
40 lbs/hr
up to 510 hp
HP-644-4, 6, 8
44 lbs/hr
up to 565 hp
HP-648-4, 6, 8
48 lbs/hr
up to 615 hp
HP-655-4, 6, 8
55 lbs/hr
up to 705 hp
HP660-4, 6, 8
60 lbs/hr
up to 770 hp
HP-668-4, 6, 8
68 lbs/hr
up to 845 hp
HP-672-4, 6, 8
72 lbs/hr
up to 925 hp
HP-678-4, 6, 8
78 lbs/hr
up to 1,000 hp
HP-683-4, 6, 8
83 lbs/hr
up to 1,065 hp
HP-696-4, 6, 8
96 lbs/hr
up to 1,185 hp
HP-108-4, 6, 8
108 lbs/hr
up to 1,390 hp
HP-122-4, 6, 8
122 lbs/hr
up to 1,550 hp
HP-134-4, 6, 8
134 lbs/hr
up to 1,670 hp
HP-148-4, 6, 8
148 lbs/hr
up to 1,850 hp
HP-154-4, 6, 8
154 lbs/hr
up to 1,975 hp
HP-160-4, 6, 8
160 lbs/hr
up to 2,100 hp
HP-168-4, 6, 8
168 lbs/hr
up to 2,275 hp
HP-174-4, 6, 8
174 lbs/hr
up to 2,350 hp
HP-180-4, 6, 8
180 lbs/hr
up to 2,450 hp
Unlimited Quantity - Available in Matched Sets of
4, 6, or 8 Cylinder Applications
good deal should i do it what to get?
PART
FLOW
POWER
HP-619-4, 6, 8
19 lbs/hr
up to 245 hp
HP-621-4, 6, 8
21 lbs/hr
up to 270 hp
HP-623-4, 6, 8
23 lbs/hr
up to 295 hp
HP-624-4, 6, 8
24 lbs/hr
up to 310 hp
HP-626-4, 6, 8
26 lbs/hr
up to 335 hp
HP-630-4, 6, 8
30 lbs/hr
up to 385 hp
HP-632-4, 6, 8
32 lbs/hr
up to 410 hp
HP-636-4, 6, 8
36 lbs/hr
up to 460 hp
HP-640-4, 6, 8
40 lbs/hr
up to 510 hp
HP-644-4, 6, 8
44 lbs/hr
up to 565 hp
HP-648-4, 6, 8
48 lbs/hr
up to 615 hp
HP-655-4, 6, 8
55 lbs/hr
up to 705 hp
HP660-4, 6, 8
60 lbs/hr
up to 770 hp
HP-668-4, 6, 8
68 lbs/hr
up to 845 hp
HP-672-4, 6, 8
72 lbs/hr
up to 925 hp
HP-678-4, 6, 8
78 lbs/hr
up to 1,000 hp
HP-683-4, 6, 8
83 lbs/hr
up to 1,065 hp
HP-696-4, 6, 8
96 lbs/hr
up to 1,185 hp
HP-108-4, 6, 8
108 lbs/hr
up to 1,390 hp
HP-122-4, 6, 8
122 lbs/hr
up to 1,550 hp
HP-134-4, 6, 8
134 lbs/hr
up to 1,670 hp
HP-148-4, 6, 8
148 lbs/hr
up to 1,850 hp
HP-154-4, 6, 8
154 lbs/hr
up to 1,975 hp
HP-160-4, 6, 8
160 lbs/hr
up to 2,100 hp
HP-168-4, 6, 8
168 lbs/hr
up to 2,275 hp
HP-174-4, 6, 8
174 lbs/hr
up to 2,350 hp
HP-180-4, 6, 8
180 lbs/hr
up to 2,450 hp
I'm assuming you're running an LS1~
I'm not too savvy on the LS1's, but I would imagine you need the same thing. I purchased the Acceleronics VersaFueler to run low-impedance injectors. It just converts your factory 'saturated' circuit to a 'peak and hold' type. Just some wiring involved:
http://www.acceleronics.com
There are other converter boxes out there, but this is what the LT1 guys typically run. If you are on a tight budget, this probably isn't the route for you to take ($$$), but just thought I'd throw the information out there...
im going to wait b4 i post their stuff because if something happens like they dont fit or some other crap i dont want to feel like an idiot by posting this stuff so people go buy from them and then are in the same boat as me.if they turn out fine and if 355ss turns out good then id be happy to list all their stuff about contacting them.i think thats fair.
