Street Racing & Kill Stories Basic Technical Questions & Advice
twin turbo supra numbers
Old 05-03-2005, 10:33 PM
xtinctbird's Avatar
Default twin turbo supra numbers
What kind of numbers does a stock twin turbo supra put up?
Old 05-03-2005, 10:44 PM
NKAWTG...N
StoleIt's Avatar
i really havent run into a stock one in recent memory.
Old 05-04-2005, 02:00 AM
Nocturnal SS's Avatar
Smile What I had seen.
With a good driver 13.4
Old 05-04-2005, 04:17 AM
GhettoTy's Avatar
very hard to find a stock one.
Old 05-04-2005, 06:23 AM
xtinctbird's Avatar
I talked my buddy out of buying a 99 cobra the he found a 94 tt supra he's wheeling and dealing on, from what I understand itr's pretty much stock
Old 05-04-2005, 08:48 AM
generalchaos's Avatar
94tt supra > 99 cobra
id tell him to get it.
Old 05-04-2005, 10:32 AM
lastcall190's Avatar
You are hard pressed to find one that's stock anymore... they were good for low to mid 13s with a good driver.
Old 05-04-2005, 10:51 AM
YlwGTO4m3's Avatar
Those things are bullet proof. You can run all kinds of boost on those engines and they just take it. Run away from the supra, there are lots of them in the 10's
Old 05-04-2005, 01:21 PM
Velocity's Avatar
Supra
Old 05-04-2005, 02:10 PM
1bdbrd's Avatar
there were running ls1 times and better in 93 when the lt1 was building steam. not a force to be fucked with especially if he knows what hes doing with it.
Old 05-04-2005, 06:54 PM
02ls1ss's Avatar
horse power there 320 at the crank but i think it would run 13.4's.
Old 05-04-2005, 07:26 PM
OrlandoFL4.8's Avatar
yeah mid 13's and just starting to pull hard. I saw a video of one (not stock) that took a while to spool up and bad traction, trapped a 12 at 130 plus mph so you know he was pulling hard up top.
Old 05-04-2005, 08:13 PM
GhettoTy's Avatar
Pretty easy to make some very good power. Theres a few recipes for under $2500 to make about 500hp. Those engines like the giggle gas too, hold up extremely well.
Old 05-04-2005, 11:27 PM
xtinctbird's Avatar
well he's more of an appearance guy, performance upgrade swould probably limited, I'm the opposite but I'd hate to get my *** handed to me by hime you know
Old 05-04-2005, 11:59 PM
sleeperstyle's Avatar
friend of mine has an anniversary edition- last year made (forget off the top of my head)
he has full exhaust, intake, mbc @ 18 psi, automatic, street tires, 12.0 @ 120 plus mph. definetly not a force to be fucked with, but they have problems hooking on the street when they get ALOT of hp- i can hold him off till 80mph in my high 12 sec. car, but after that he flys right past me. supras are dyno queens for the most part, but still with that type of mph they will catch your *** at the end!
Old 05-05-2005, 12:37 AM
GhettoTy's Avatar
last year was 98. After what you friend has done it starts to get very expensive to mod a Supra.
Old 05-05-2005, 07:37 AM
Yep, on a budget, the twins are the way to go. There's even more left in the car, at only 18psi. Good luck in your race, any idea what mods he has?
Old 05-07-2005, 09:29 PM
Z71/99's Avatar
I had one, stock turbo w/ an aftermarket boost controller, "boost cut controller" "BCC", rmm downpipe, and a HKS super dragger exhaust and I was runnin about 18psi and I pulled a 11.8 w/ no traction below 25 on stock tires. Thats about $1300.00 in parts. I changed to a ts04 w/ cast manifold (the cheap one) and could break loose at 35! Got to 165 and backed off. Scary 4 my ***** ***.
Old 05-08-2005, 03:21 AM
mimic42100's Avatar
I ran a supra with stock twins, and a boost controller.
son of a bitch was pushing damn near 19-20 psi (it's been a while, memory fog on those numbers. dont hurt me ).
Lets put it this way, he missed a gear, i walked about...oh 4-5 cars, then he ripped my passenger side door off.
The supra's might be dyno queens. but ****, when i used to lurk on supraforums.com (before i realized getting a supra is damn near IMPOSSIBLE), i was looking at the bpu packages that can push you all the way to 800 hp, on a stock block and cam.
yeah, the supra, for all purposes, is the god of boosted cars.
They arent drag cars like ours are, but get one on the freeway, and enjoy the view.
Ninja Edit: Unless you drive that turbo'd ls1 on here, that walked the dude in the supra.....that dudes car is badass =)
