Poly motor mounts
6 Second Club Moderator
Poly motor mounts
Whats the trick to get the ploy motor mounts to line up? They do NOT line up like the stock ones. Unless something is different when using a 6.0L block. It seems that they are making the holes wider apart. I can't get the second bolt through! Maybe you need two people, I was working alone tonight. I will try again in the morning with some help.
I had a little trouble w/ mine too (LS1 block). I finally got it by gently prying on it. Make sure all of the K-member-to-pedestal bolts are loose. Be careful not to cross-thread it!
I had some trouble with mine too. I actually took 3 of the 4 pedestal bolts out to get mine on. Wasn't terribly easy getting it all line up, but it was worth it in the end. I would recommend loctiting the pedestal bolts, as I had 1 on each side that was barely snug.
It was tough for me too. After a bout 10 minutes of moving the motor in different angles, it finally slid through. You just have to find the right angle I think and it will go..
Dan
Dan
Yep, PITA,.....LS1...... I had the pedastal bolts in but loose....I had a floor jack under the oilpan... basically, by myself- I worked the floor jack with my foot/leg and jiggled it a bunch.. it eventually lines up.
Well with my luck something was WRONG! I got it in, but it was with a car lift, engine hoist and a floor jack. I also had to loosen the k member. No angle would work. These mounts were one inch from fitting. I've have had my motor out three times, I know it's not me. Oh well it's in.
Originally Posted by 72sub
That's exactly what I did. I'm sure I looked like I was doing some kind of crazy exercise or something.
Once I had bolts loose, I was able to get a tapered punch in the hole from the back to pry the mount close enough to the hole to get it started. One of my problems was I had the motor to high, but the punch did the trick.
Location: Used to live in South Texas, Now in North Carolina
When I put my motor in the driver side when right in but the pass side was a pain. i didn't have to loosen the pedistals, just had to play with a jack and engine hoist for about 30 min.
I used a large pry bar between the pedastal and clamshell, and guided the motor as I lowered the jack. Also, are you sure the mount is installed in the clamshell correctly?
