Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
396 stroker small block
Old 05-06-2005, 12:01 PM
Vortec355's Avatar
Default 396 stroker small block
I want to build my 350 into a 396 stroker. I was told H beam rods won't clear and I would have to grind into the water jacket. I could use I beam billet rods but they are $800. Has anyone successful made a 396 stroker with H beam rods?
Old 05-06-2005, 08:01 PM
smask04C5's Avatar
are you still using a .030 over bore with a 4 inch stroke, is that your question?
Old 05-06-2005, 09:43 PM
AutoRoc's Avatar
I have one over here with a 4.03" bore and 3.875" stroke. Eagle crank and 6" H-Beam rods. I don't believe any jackets were hit when it was notched. The rod bolts(1 anyways) did contact the camshaft, which required a swap to a smaller base circle cam.
Old 05-06-2005, 10:16 PM
Vortec355's Avatar
AutoRoc thanks for the input. I was planning on going with 4.030 bore and 3.875 stroke. I'm going with eagle crank and H-beam rods and flat top pistons.
Old 05-07-2005, 07:41 PM
slow trap's Avatar
the water jacket shouldn't be a problem but you will need to do alot of clearancing in the oil pan area,especially with a 3.875 or 4 "stroke and h beams.small base circle cam will probably be required also.some blocks are different than others so you never know until you check.
Old 05-08-2005, 02:22 PM
AutoRoc's Avatar
Canton's 82-92 Camaro oil pan was the only one that fit I was told so mine's got that. Definately do the small base circle cam, it will save a headache.
Old 05-09-2005, 07:03 AM
chuntington101's Avatar
i think american speed where doing an all stroke 401 ci from a 350 block. i know the block did have clearing mods done, but thats all i remember. have a look on the American speed site or look at car craft's web site (tech articles) for more info.
thanks Chris.
Quick Reply: 396 stroker small block
