minimum pulsewidth measured
I built this setup to measure the minimum pulsewidth for various injectors. By minimum pulsewidth I mean the shortest pulsewidth that results in enough fuel flowing through the injector for an engine to idle.
http://para.noid.org/~lj/InjectorPulseTest.jpg
I've only looked at three part numbers so far, all made by Siemens-Deka, and all tested at 43 psi fuel pressure. Here's what I found:
60 lb/hr high impedance: 1.5 ms (this injector has a "Mototron" part number in ink)
72 lb/hr low impedance: 0.8 ms
83 lb/hr low impedance: 0.9 ms
As expected, the high impedance injector had a fairly broad transition from no flow at all to a reasonable stream, whereas the low impedance injectors had a sharper cutoff. I'm convinced that is why guys have a hard time getting the big high impedance injectors to work well at low loads.
Originally Posted by RedHardSupra
sweet setup! thanks for sharing the data. are you able to do more testing for other popular sizes, like svo 30/42s?
Originally Posted by CHarris
I've got the Motron 60's running well at 1.8-1.9 ms on my combo listed in my sig...
BTW, CHarris, do your injectors say Mototron on the body? Or Motron?
