A Factory Chevrolet Ls6 Z06 Camshaft
Old 05-12-2005, 02:13 PM
slow98transam's Avatar
Default A Factory Chevrolet Ls6 Z06 Camshaft
Would this be an ok upgrade if I am looking to get only around 400 horses with the headers and the LS9 intake. I dont want to get to much horsepower because I still want a good daily driver thanks for all the input.
FACTORY CHEVROLET LS6 Z06 CAMSHAFT AND YELLOW VALVESPRINGS
218/204 DURATION AT .050
.550/.550 LIFT
117.5 LOBE SEPERATION
LS6 SPRINGS ARE GOOD TO .570 LIFT
Old 05-12-2005, 02:20 PM
White 02 WS6's Avatar
You will achieve 400 fly wheel horsepower, but you wont put 400 to the ground... Not familiar with the LS9 intake...I suppose you mean LS6 intake...There are plenty of bigger cams with great drivability and will build some nice power...
Old 05-12-2005, 02:56 PM
blkZ28spt's Avatar
You almost surely will not make 400 rwhp with the LS6 cam. If you SEARCH there should be a decent amount of info on this cam.
Old 05-12-2005, 04:06 PM
SSpdDmon's Avatar
.550/.550 LIFT
You should look into the 224 cams (ie - 224/224 .563/.563 114lsa). They're relatively mild for a cam and you can make some nice power with one. With a good tune and bolt-ons, it should get you 370~380hp at the wheels. A good set of heads should get you to ~400rwhp.
Old 05-12-2005, 05:01 PM
Ryan02SS's Avatar
Coming from someone who has run an 02 LS6 cam, I say get a 224, 225 or 226 grind on a 114LSA. After tuning will drive the same as the LS6 cam but make more power everywhere through the powerband.
LS6 cam w all bolt ons stock heads................
TR224 w same boltons and same stock heads..........
Old 05-12-2005, 05:25 PM
cyphur's Avatar
What he said.
Old 05-12-2005, 05:41 PM
Buddy of mine made 429 through a stalled auto with a C2 cam from MTI (224 224) and a good set of heads...His car went 10.7's with a 3800# race weight.
Old 05-13-2005, 08:22 AM
Ok how about this will this idle bad and will it work with stock heads 228/230 571/573 112 + 4 LSA from Comp Cams
Old 05-13-2005, 08:24 AM
I just wanted to add I will not install this I have done everything else but there is a certain fear of messing something up internally. The external stuff I am cool with.
Old 05-13-2005, 08:30 AM
Or how about this one Lingenfelter GT2-3 Sleeper Cam Specs Are AS Follows 207/220/ 573/580 118.5LSA
Old 05-13-2005, 08:34 AM
JZ'sTA's Avatar
Go with something like a 224/228 581/589 on a 114 and you will have nice power and be very streetable.
Old 05-13-2005, 08:35 AM
JZ'sTA's Avatar
I think he has a 50 shot hidden somewhere.
Damn those numbers are impressive.
Old 05-13-2005, 08:40 AM
A sneeky pete in the door
Old 05-13-2005, 08:59 AM
777's Avatar
or a set of stg 2 heads
Old 05-13-2005, 09:31 AM
JZ'sTA's Avatar
I was J/K about the 50 shot.
I dont doubt anyone's numbers I don't know.
That is real fast for that size cam, but hell using a 4600 stall could probally get him there.
He could also have done high compression pistons and is running 13:1 with race fuel for all I know.
Now I am wondering.
How in the hell is this possible.
In a 3800 lb car, with a cam that makes peak power around 6200? Gotta be something more then just you everyday AFR head 224 cam 90/90 setup to run these times with a car that heavy.
I am calling BS without acturally raising the flag.
Old 05-13-2005, 12:23 PM
Its all good we never know until you actually get with some one and talk to them in person
Old 05-13-2005, 01:00 PM
DONAIMIAN's Avatar
I broke 400rw with an MTI T1(221/221 .558/.558 112) its a good cam for its size. I cant really tell you about the driveability because I have an aluminum flywheel and stage 4 clutch. Id imagine it would be a lot better with a stage 2 or 3 with a heavier flywheel.
Old 05-13-2005, 03:06 PM
NviouSS's Avatar
that's a better cam than the LS6 imo. they both have the same characteristics but the GT2-3 makes more power. i'm running it and am making 370 rwhp with LT's, ORY, and lid. this is also untuned and w/o a pulley. i could be around the 400 rwhp make if i made the changes.
Old 05-13-2005, 03:42 PM
Thanks I will think about that one the GT2-3.
Old 05-13-2005, 03:44 PM
Default Did you need to upgrade heads cam or springs
Did you need to upgrade heads cam or springs on these and with this cam can you keep up with the 03 cobras
