408 guys????
Old 05-19-2005, 09:55 PM
TN94Z's Avatar
Default 408 guys????
Well, it looks like I am buying a 408 nitrous motor. My question is for you 408 guys...what kind of intake are you running? Will the LS6 intake be good enough or are you guys running the Fast setup with the bigger TB?
Old 05-19-2005, 10:04 PM
2c5s's Avatar
90/90 all the way.
Old 05-19-2005, 10:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
Originally Posted by 2c5s
90/90 all the way.
I agree.
Old 05-19-2005, 10:45 PM
1QuickT-A's Avatar
the LS6 intake will work fine but of course it is gonna be a lil restrictive for a motor with big cubes.. but it wont hurt anything if you wanted to use the LS6 until you could buy a Fast 90/90. just expect to see a BIG change in numbers when you do the swap.
Old 05-20-2005, 01:20 AM
JZ'sTA's Avatar
90/90 here.
I dont see the point of droping 7+ thousand dollars on a 408 with stage 3 heads, and going cheep on the intake and TB.
Just my oponion.
We spend 2000++ dollars on heads to get a extra 40-50 horse power, kinda the same thing as spending 1100 for 20-25 horse power.
Old 05-20-2005, 05:18 AM
beardWS6's Avatar
I bought all the 90mm stuf for my 408 build in the future. For now, everything is on my little 346! She does breath well!!!!
Old 05-20-2005, 06:59 AM
TN94Z's Avatar
Well, I have a LS6 intake already and wont' be able to buy the Fast stuff right away. That is why I was asking
Old 05-20-2005, 07:02 AM
DAPSUPRSLO's Avatar
Depends on your goals. If you are 7000 and below I'd say the FAST is the way. If you are over with heads that flow to .700-.800 then a sheet metal or gmpp may be the way to go. I'm going with a gmpp myself.
Old 05-20-2005, 10:34 AM
1BDHWK's Avatar
I was originally going to run my DP LS6 intake on my 408, but couldn't see spending the money on motor that needs more air, and not give it to it. I found a 90mm LSX on E-bay for just over $700, and went with a NW TB. Your motor will still run great with the LS6 intake, but it will run better with the 90/90.
Old 05-20-2005, 07:29 PM
TN94Z's Avatar
That is what I figured. Don't get me wrong, I know that Fast will make it run alot better..I was just curious how the LS6 would do until I can get the Fast setup. Thanks guys. Any of you guys solid roller?
