Which motors compression would work better for n2o
Old 05-21-2005, 01:08 PM
MakoLS1's Avatar
Default Which motors compression would work better for n2o
9:1 or 11.3:1 compression? Would i be safe with say a 200shot with 11.3?
Old 05-21-2005, 01:50 PM
Robert56's Avatar
With the fact that n2o works well with compression 11:3 is actually a good street/strip compression for nitrous motors.
Old 05-22-2005, 07:01 PM
MakoLS1's Avatar
Im wanting to spray at least 200 on it... I know stock 10:5 worked well on my stock motor. I dont want to have so much where i risk detonation would i be safe on 93 octane pump gas?
Old 05-22-2005, 07:27 PM
Restricted User
CAT3's Avatar
11.3, hell my shortblock was built for 200+ shots and it will be over that for a little while Think I will be installing it sometime end of June begining of July...cant wait. With tuning you surely could run pump gas.
Old 05-22-2005, 09:29 PM
Elite_Hot_Rod's Avatar
What type of block, what's the bore size, what heads and have they been milled, if so how much?
Old 05-22-2005, 10:03 PM
MakoLS1's Avatar
its an slp zl402 iron block. ls1 heads, they have been ported but not shaven.
Old 05-23-2005, 06:12 AM
BTL FED's Avatar
The more compression the better, nitrous loves compression
Old 05-23-2005, 06:45 AM
Big Mike's Avatar
Old 05-23-2005, 04:56 PM
Personally I'd try and stay somewhere around 11.5 to 12:1 compression ratio for the bottle but mines alittle higher than that.
