Does anyone make a 1.6 ratio rocker for LS1?
Old 05-24-2005, 12:19 PM
LS1TECH Sponsor
mikey's Avatar
Default Does anyone make a 1.6 ratio rocker for LS1?
Anyone know?
Old 05-24-2005, 12:59 PM
LS1 Tech Administrator
Patrick G's Avatar
The only company I can think of that might would be Jesel. Maybe T&D.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 05-24-2005, 01:02 PM
MUSTANGEATER's Avatar
I think it's gonna be a custom Rocker arm. I'm sure someone like Bauer, Curtis or Straub will know and chime in though
Old 05-24-2005, 09:38 PM
427's Avatar
Jesel makes 1.6 and 1.5
Kurt
Old 05-25-2005, 12:40 AM
GrannySShifting's Avatar
Jesel does. Ive been working on a cheaper alternative probably for what you are thinking Mikey
Old 05-25-2005, 02:27 AM
SStrokerAce's Avatar
Jesel and T&D both do. Jesel even makes one for the C5R head.
I actually wouldn't mind this, it would play less hell with the PR's if the lifters don't run out of oiling because of the lift. I guess the new Crane lifters can take .400+ at the lobe and they are still safe so that's .640" lift on a 1.6:1 Rocker.
Bret
Old 05-25-2005, 02:28 AM
You should have put Kurt in there as well Floyd.... Smart MF'er in my book.
BTW Kurt those new Daytona Prototype LS rules really suck. No Porting the LS6 castings and now 5.0L, the LS is a monster compared to the other motors in there, but looks like the Lexus is finally competiting with it.... I like how the Porsche motor says 3.9L and any modifications in comparison.
Bret
Old 05-25-2005, 09:57 AM
SSCamaro99_3's Avatar
For us average dummies, what advantage is there to be gained?
Old 05-25-2005, 11:17 AM
Bret roughly how much is a half set of jesel rocker bodies? Need some for an exhaust lobe
Old 05-25-2005, 12:03 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Since the rocker moves less, the higher the motor can be spun.
Keith
Old 05-25-2005, 12:14 PM
A higher ratio rocker will give you more lift obviously, and faster valve action. It also means for the same max lift at the valve you will have a larger base circle so the cam will be stiffer.
On the other hand the drawbacks come from the fact that the rocker will mulitply the loads from the valve spring back thru the pushrod. The higher loads will deflect the pushrod, rocker stud more and put more pressure on the lifters which will destroy stock Hyd Roller lifters faster or wear out needle bearings on solid rollers faster with the higher valve spring pressures.
There are advantages and drawbacks to both. I can go into that if ya want but I'm hungry, so if ya want ask I'll see what I can do.
Bret
Old 05-25-2005, 12:17 PM
Wish I could tell ya... dont want the post natzis after me.
Old 05-25-2005, 12:22 PM
Hell with them, LTOne4Fun@aol.com
Same reason why Fords with steel valves and 8000 rpm on stock lifters dont run 1.8 rockers
Old 05-25-2005, 04:21 PM
Bret
Most of that makes sense. If you want to add more, I am aways up for learning something new.
Old 05-25-2005, 05:51 PM
Bret
I'll add him to the list now Bret
Hey you think we can talk about varying rocker ratio's? Like 1.7 intake and 1.6 exhaust??
Just like throwin' ideas out
Old 05-25-2005, 09:55 PM
Brian Tooley Racing's Avatar
Originally Posted by mikey
Anyone know?
Mikey, I have a set custom made by Harland Sharp, I no longer need them as I now have the Jesel Y2K setup, I will PM you.
Old 05-26-2005, 10:32 AM
I'm actually writing a novel on all of this on Word now... might take me a bit.
Bret
Old 05-26-2005, 11:04 AM
cyphur's Avatar
Bret
I'd be interested in seeing that.
Old 05-26-2005, 01:15 PM
I'm probably going to write a whole thing on valvetrain and cams. Might turn into a story for a magazine since I have some buddies who are editors but I will still post the part that is relavant to this here.
Bret
Quick Reply: Does anyone make a 1.6 ratio rocker for LS1?
