nitrous all the sudden doesnt spray anymore?
well for some reason, it doesnt want to spray..When i have the nitrous activated, i dont see any gains or pressure loss?
i looked at my fpss and noticed a loose conection, tighten it, and still same problem!
what could be wrong here?
Randy
Randy
12 Second Truck Club
empty bottle just kidding, had to throw it out there.
are your solenoids clicking at all? do you have a window switch? is your fpss set too low? is your bottle open? is there power at the switch? is there power at the fpss? is there power at the solenoids?
well before when i would clear the lines, i would turn the bottle off and empty out the rest of the lines by spraying!
Dont have a purge yet!
and when id id run yes the bottle was closed, but usually it would still spray if it was closed..
im going to go open it and test it out when i go to the gym and see if thats the problem!
i think my fpss switch is messed up, casued i hosed my engine bay down and didnt cover that up, adn its been liek 3 weeks since then, but it just isnt workign!!
i think it ended up being a FRIED relay!!!
i tried to bypass the fpss and still nohting...
looked at the relay and it had white **** and black burns all over it
so im going to get a new one and see if that fixes the problem!
Randy
Randy
Randy
Randy
Originally Posted by 69_YENKO
hopefuly thats it, easy $4 fix if it is. I had a relay go bad and it melted all up. also though i had a relay problem once and it turned out to be my ground for the relay had come loose.
got the realy and still no worky!
