Ok to remove bumpstops?
Old 05-28-2005, 03:29 AM
burnout04's Avatar
Default Ok to remove bumpstops?
Hey Bumpstops are a pain in my ***, and I've probly never even hit them. Is it cool if i just cut them out all together from the fender down?
Old 05-28-2005, 12:57 PM
69TA's Avatar
Just take them out. Unless you plan on taking the car airborne......then in that case leave them in.
If it bothers you not having them there, you can always get bumpstops that go around the shock shaft. Like the ones you find on aftermarket Koni's
Good luck,
Kevin
Old 05-28-2005, 04:40 PM
Wyckedcamaro's Avatar
i cut mine and will be doing like 69ta says.."Helpers" they are called
No bumpstop needed. They get in the way of making your rim/tire combo SEX
Old 05-28-2005, 06:22 PM
StealthFormula's Avatar
whats a bump stop? Where exactly is it?
Old 05-28-2005, 08:11 PM
JB151's Avatar
Was wondering that myself.
Old 05-29-2005, 02:04 AM
burnout04's Avatar
look in your rear fenders, its a metal piece sticking out in the middle of your back fenders with a rubber bumper attatched to it. hard to miss
Old 05-30-2005, 04:58 PM
JasonWW's Avatar
Here are what the rears look like.
If you are at stoock rear height, you can take them out without any problems. If you are lowered, you will need them.
Old 05-31-2005, 09:55 AM
Xsta Z 28's Avatar
I would NEVER remove them . . . Body / suspension / tire damage is inevitable without them, especially in a lowered car . . . GM doesn't put, unessecary part on their cars . . .
Old 05-31-2005, 10:27 AM
JasonWW's Avatar
They do play it overly safe, though. The bumpstops they use are overly stiff and limit usable suspension travel.
To clarify your response, I will say that the axle will hit the exhaust pipe, first, then the DeCarbon shocks will bottom internally.
I ran 315's for a quite a while at stock height with no bumpstops and had no problems, I also measured the rear travel just to make sure. I did a whole write up if anyone is interested.
Stock Shock and Suspension Travel Specs:
http://frrax.com/rrforum/index.php?a...=818&hl=stock&
