Cam Emissions
If you have to pass the sniffer then there's no way in hell it'll pass. If it's only a visual inspection and you can get by with your current setup using the long tubes than changing the cam won't change anything.
Originally Posted by travis00
Yes I passed with the lts. Someone told me that I wouldn't pass if I had a cam any bigger than a 224/224 114lsa. But I find that hard to believe.
If your emission testing does not require a sniffer test then you can get away with a lot bigger as long as the computer isn't throwing any codes which again comes down to a good tune and a great tuner.
Good luck
