First fill and bottle leaking.....
Old 06-04-2005, 07:50 PM
1320_PERFORMANCE's Avatar
Default First fill and bottle leaking.....
I filled my 10lb tnt bottle yesterday, this morning I noticed a heasing sound comming from the fitting where you hook up the blow down tube to...I sprayed water on that one fitting and it bubbles up pretty good....what do I have to do to fix this problem? do I just use teflon tape to seal the threads?
Old 06-04-2005, 08:37 PM
Brett95z's Avatar
Teflon paste would work much better.
Old 06-04-2005, 09:10 PM
theblur98ss's Avatar
If it's coming out where the blow down tube is I would say the relief valve is bad on your bottle. Either that or you have some serious pressure in there.
Old 06-04-2005, 09:27 PM
MetallicaMatt's Avatar
doooooon't use teflon tape...it'll clog your system
Old 06-04-2005, 10:40 PM
Ill wait till I empty the bottle, remove the blow down fitting and use teflon pase...if that does not work would tnt help me out on this issue?
Old 06-04-2005, 11:47 PM
David@TNT's Avatar
If it was leaking where the blow off cap tightens to the valve, just try tightening the cap, if that dosent work give me a call on monday and I will get you another one on the way..
Old 06-05-2005, 04:14 AM
35th SS's Avatar
alright Mark.never use tape use the paste teflon.if its still leaks send it back.good luck man.
Old 06-05-2005, 08:53 PM
TN94Z's Avatar
My instructions said to install the blow down tube fitting with dry threads
Old 06-06-2005, 09:01 AM
Nitro Dave's Nitrous Outlet's Avatar
Yes,
Do not use paste on this part.It should seal with dry threads.Do as David said.If tightening it does not stop it.You probley have a bad blow off disk.
Dave
Old 06-07-2005, 12:44 AM
Originally Posted by Nitro Dave's Nitrous Outlet
Yes,
Dave
Tightened up the thread yesterday after reading David@TNT's reply...re-checked bottle pressure on gauge and it came all the way down to 3/4 hundred PSI..Dave@TNT Ill be sending you a pm....thanks guys...
Old 06-08-2005, 04:22 AM
Just Wanna thank Dave @ TNT for the great and fast customer service...
