100dry + 150wet what all is needed?
Old 06-09-2005, 05:26 AM
Flamin Raven's Avatar
Default 100dry + 150wet what all is needed?
I currently have a TNT F1 kit jetted for a 150shot. I want to add a 100 dry on top of it as a 2nd stage. What all is needed fuel sytem wise? I have a fully forged bottom, Racetronix intank fuel pump and 30lb injectors. Do you guys think this is enough?
Who all is running a dual dry/wet setup sucessfully? Also what plugs would you run with this? TR8's?
Old 06-09-2005, 09:04 AM
Nitro Dave's Nitrous Outlet's Avatar
TR6 plugs should still be fine.Since you have a built motor you will probley need injectors.Does your Racetronix fuel pump have the Hot Wire kit also?
Dave
Old 06-09-2005, 11:16 AM
Robert56's Avatar
Are these the SVO 30lb injectors? I would do the dry as first for the tune part, but that's just me.
Old 06-09-2005, 11:31 AM
Dave
Yes, I forgot to mention that
Originally Posted by Robert56
.Are these the SVO 30lb injectors? I would do the dry as first for the tune part, but that's just me.
Yes they are SVO 30lb redtops.
I was planning on leaving on the 100dry as a first stage then having the 150wet come on 100ft out
Old 06-09-2005, 01:42 PM
Navy David SS's Avatar
All the safety stuff - window switch, WOT... one heck of a tune, great suspension, a set of great rear tires, and great big "ones" I would believe the SVO 30# (which is our 36#) should be fine. Run some good race gas, you should NOT have to pull all that much timing. I hope you don't have a stock tranny and rear-end.
Good luck
David
