mods for LOng lasting transmission
What are all the things possible to get to make the trans last a long time?
so far i have learned
-trans temp gauge
- trans cooler 24k btu +
-deep trans pan (is it good for lowered cars?)
-full synthetic fluid?
-transgo shift kit
anything else? best places/prices to get these?
thanks
-trans temp gauge
-transgo shift kit
thanks
I'll second the standard tranny fluid. I recall reading that it's because the organic clutch material wears quicker with synthetic fluid. I recently got my newly rebuilt tranny back (Max Evil, through speed inc) and Larry recommended I change to synthetic fluid after ~1k miles of break in.
If you want your tranny to last longer than mine do everything on your list and:
Do not let it get hot. Try to keep it under say 210* at all times, and don't get on it when the temp is over 200*.
Avoid WOT downshifts. In other words, highway rolls. 4-2 downshifts are killer to these trannies. (wish I knew that earlier ) What larry at speed inc recommended if I did want to go from a freeway roll was to put the shifter into drive (3) and go from there. Even then, it's better not to.
Change the fluid every year/15,000 miles or so, depending on how hard you are on it, how much you race it, etc.
So are you saying just to leave it in OD and floor it?? Or no highway racing at all is good?? I heard WOT in OD was bad??
I still wonder why it's not, or if it actually is, good to put the shifter into second while cruising along then punch it and push the shifter up to drive. Oh well.
WOT in overdrive as in fourth gear is bad. In general if you are racing it is better to put the shifter in "drive" than "overdrive" (3 for firebird owners). It's best to completely avoid or at least minmize highway racing from a roll, but if you are going to do it (I used to do it a lot) it is best to do it from drive.
10 Second Fun Car
Ive got an upgraded transmission, by not a sponsor. Ive got about 40-50k with trans and synthetic fluid(Royal Purple). I believe it actually saved my trans. The cooler line came off on the freeway. I lost 4.5 quarts! Put more back in it and havent had any problems since!
i think its a same that GM desined and implemented a transmission that cant be punched from a roll. i have smoked the 2-3 clutches in a 4l60 3 times, finally gave up on them and switched to a th350 manual valve body. i like it much better. id reccomend a deep trans pan, and straight made in the usa ATF, no synthetic.
