whats right with this 12bolt and setup
Old 06-14-2005, 12:37 PM
SLP/Drew's Avatar
Exclamation whats right with this 12bolt and setup
made up my mind im getting a 12 bolt over a 9"...I had made up my mind on the 3.73 but it seems that most people favor the 4.10...
This is what I want...I want a gear ratio that will put some mean torque down but I dont want to break my tires loose when I tap on the gas.
Im about to put a procharger in then ill be running around 450wrhp and around the same amount of torque. Is the 4.10 better for higher power f-bodys or is it better for mostly stock cars???
(im running on 295/40/18 Kumho's)
Also! how much more lowend torque and power will get to the rearwheels running a 4.10 over the stock, and will it severly kill my top end speed???
Old 06-14-2005, 01:25 PM
Blacker's Avatar
From what I gathered:
4.10 - NA
3.73 - FI
Old 06-14-2005, 02:45 PM
SLP/Drew's Avatar
4.10 - NA
3.73 - FI
not sure if i understand your post???
Old 06-14-2005, 02:48 PM
Blacker's Avatar
4.10's for a naturally aspirated engine
3.73's for a forced induction engine
Old 06-14-2005, 04:00 PM
SLP/Drew's Avatar
really...thats intresting, ive never heard that. Im curious the reasons why that is so. Is it because FI yeilds more power/more wear and tear on the rearend or what???
Old 06-14-2005, 05:34 PM
Blacker's Avatar
You would run out of gear quicker with 4.10's and FI. That is, you could be shifting to 5th. With a 3.73, you would stay in 4th. I am assuming you have a M6.
Old 06-14-2005, 05:49 PM
BBQLS1's Avatar
I think 3.73 will definately be the better choice. But I expect with the procharger, you will still break the tires loose.
Old 06-14-2005, 05:50 PM
BBQLS1's Avatar
You'll get to the end of your power band too quick with the 4.10s. Most of the time that is the case.
Old 06-14-2005, 06:40 PM
SLP/Drew's Avatar
ok, thanks guys for the info...yes it is an M6...the guy I talked to also recomended 33spline what is yalls imput on that? oh yea for the brakes are we 4channel or 3 channel (so I know how to fit the rearend with brakes)
