using wideband to tune??
Old 06-15-2005, 11:38 PM
bmfcamaro's Avatar
Question using wideband to tune??
for part throttle do i use the % afr error or the actual afr readings to do the adjusting to the ve? also i am following the writeup on hptuners website. is this a good one (how to tune using wideband)? should i change my coomanded to 13 like it says??
Old 06-15-2005, 11:41 PM
Robert56's Avatar
Wideband Tricks
Old 06-16-2005, 07:37 AM
405HP_Z06's Avatar
13:1 AFR is recommended because it's safe. You can use whatever AFR you want, just make sure it's a safe one. As far as what to use to correct the VE table, use the % AFR error as it's easier.
HTH,
Old 06-16-2005, 10:20 AM
bmfcamaro's Avatar
not sure how to use the % error to correct. the afr you do afr/13=ve change right.
Old 06-16-2005, 02:28 PM
405HP_Z06's Avatar
The same copy/paste special when using the LTFT histogram on the VE table. Select the % AFR Error histogram and copy, then paste special > multiply by % on VE table.
Old 06-16-2005, 03:57 PM
bmfcamaro's Avatar
my afr error is crazy like 10-30's that is a lot to multiply by. 10-30% that is.
Old 06-17-2005, 10:15 AM
bmfcamaro's Avatar
t t t
Old 06-17-2005, 10:29 AM
SSpdDmon's Avatar
What conditions are you seeing that kind of error? Did you turn on DFCO?
Old 06-17-2005, 11:20 AM
405HP_Z06's Avatar
Have you verified that your WB display and what HPT is logging is the same AFR? If these are the same, the number is what the number is. Are you trying your best to drive in steady state conditions? Have you verified that you don't have any mechanical issues contributing to the large error %?
Old 06-17-2005, 04:46 PM
bmfcamaro's Avatar
can i email them to you 405hp_z06 so you can check it out?
Old 06-17-2005, 06:14 PM
405HP_Z06's Avatar
Send away and I'll check it out.
z06_pwr@mac.com
