Which fluid with a Detroit TrueTrac and Moser??
I know synthetic is not recommended with the Eaton, but do I want to use synthetic or regular rear fluid with the Detroit TrueTrac?? Which fluid is best in this case, and do I use the additive like with the Eaton??
The preferred fluid should be noted with the instructions that came with the TruTrac.
You do not need to use the additive for a helical posi.
I prefer the Mobil 1 75W-90 with no additive in my Torsen rear-end. It quieted the whirring noise I was getting.
Originally Posted by pla-tym2
Moser recommends petroleum base gear oil (not synthetic). I just installed a Moser 12 Bolt w/ a tru-trac. I prefer to use Mobil 1. I wonder why Moser says no.
rule, but have read some really good things about the gear oil made by Amsoil, Redline, and others. It seems they have come a long way in engineering the shock loads on big gears, and of course they lube better while keeping things cooler. If I had the nerve to try it, and was sure it would work without somehow damaging things, I would be all over the synthetic heavy duty oil.
Wonder what Strange, Currie, and other manufacturers say about it?
With the Eaton posi, you must use petroleum gear oil, because synthetic will give unnecessary wear on the clutches.
